Question about Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT
Prolanpro riding mower manual to fix belt on deck model + pb195h42lt
mowerman1857
  • 389 Answers
SOURCE: I have a Poulan riding mower and it has a 42
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
Posted on Oct 31, 2009
miket756
  • 2702 Answers
SOURCE: My riding mower has a 42
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Posted on Jun 26, 2010
Testimonial: "No, not at all I had a new belt put on and the technician measured both sides and adjusted to same height."
  • 8404 Answers
SOURCE: We have a 48" 23 hp poulan pro riding mower, our
More than likely, you are using a automotive belt not a "V" belt. Automotive belts are pretty tuff but can not stand up to the beating a mower takes. Go to your mower place and get the proper size "V" belt for your Poulan. Make sure it is both the proper size and a quality belt. I recommend "Gates" belts.
When you start your mower, start it with the engine at slow speed, to lessen the shock that the belts and clutches take.
Thanks for your interest in FixYa.com
Posted on Aug 16, 2010
2strokeguy
  • 183 Answers
SOURCE: what is the deck drive belt length for this mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Posted on Sep 10, 2010
  • 4 Answers
SOURCE: mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Posted on Nov 08, 2011
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need diagram of deck for 2006 super bronco model 6605
I DON'T HAVE IT ON HAND, BUT YOU CAN TYPE IN ON GOOGLE SEARCH "YOUR MODEL # DECK BELT DIAGRAM" TO FIND IT, BUT TO DO IT YOURSELF, JUST REMEMBER THAT BLADES MUST TURN COUNTERCLOCKWISE AND THAT GROOVED PULLEYS MUST FACE THE INSIDE OF BELT AND FLAT PULLEYS THE OUTSIDE OF FACE OF BELT, ALSO REMEMBER THAT SOME MODELS HAVE JUST ONE BELT (DRIVE AND DECK BELT) OR TWO BELTS (DRIVE BELT AND DECK BELT)
Jul 08, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Need to put drive belt on poulan pro model pb195h42lt
You can search on amazon for belts... take a look: Amazon com Craftsman 42 in belt. I hope this was helpful. Cheers
Sep 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT Logo
16 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
