I need the universal remote code for a toshiba theaterview sd dolby digital tvto program my remote
5 Suggested Answers
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
  • 11 Answers
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
Posted on Dec 12, 2008
  • 1335 Answers
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
Posted on Sep 02, 2010
I've got a Digital Stream Dolby digital DTV box, I need to know what codes will work to program It into my GE universal remote control.
Code, if applicable, will be in your GE remote. Use code search to find the applicable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store possible codes.
Aug 16, 2016 | GE Televison & Video
Need codes for he universal remote to program to Toshiba DVD player SD-1800
Use the code search provision of your universal remote to seek a suitable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 03, 2016 | Toshiba SD-1800 DVD Player
Trying to set up my universal remote. There are dolby list, I have a dolby digital dvd. I need a code for the dvd. I hope you can help me. Thanks Mr Cyrus
The code depends on TWO factors... the equipment you are trying to program, and the type of remote.
Here is some useful info:
http://www.videohelp.com/dvdhacks/alba-dvd108/1310
Sep 26, 2010 | Alba DVD-108 DVD Player
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
I need to program a universal remote for a Toshiba SD-K510.
it is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Jun 07, 2009 | Toshiba SD-K510 DVD Player
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
Jul 27, 2008 | Televison & Video
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
