Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630H - Fridge temperature will not go below 14
The freezer temp is working fine. The Fridge temp will not got below 14 degrees. It should be around 6 degrees. Please help!
  • 1 more comment
  • SKEK Aug 31, 2007
    Have tilted the unit and cleaned surfaces with cloth, pushed upright and turned on, have waited 5 minutes and temp of fridge remains at 20minutes. Is there anything else I can do?
  • SKEK Aug 31, 2007
    Temp is now at 19oC, how long should it take to come down to the display temp.
  • SKEK Aug 31, 2007
    There is some noise coming from it, but not as loud as I recall it when it was working fine. Can the compressor be easyily replaced?
    Sergeant:
  • 279 Answers
The first thing to do is clean out from under and behind the refrigerator thoroughly. In over half the cases like this, I've found it's just a matter of not enough air getting to the compressor, because of dust bunnies or other things blocking the airflow. You'll need to empty it and tilt it back to clean out from under it properly. But I will be surprised if that doesn't fix your problem.
Posted on Aug 31, 2007
  • 1 more comment
  • Anonymous Aug 31, 2007
    Give it about an hour. If it still doesn't change, then you may need to have your compressor replaced.
    Can you hear the fans running? If they're not running, that could be the problem too.
    I don't know exactly.
    We left ours overnight, and it was doing great by morning. So I'm not sure how long it took exactly, but it was some number of hours.
    You'll want to test it, and see if the compressor motor is bad first. I found detailed instructions here:
    http://www.acmehowto.com/howto/appliance...
    Still, I'd give it a few hours first and see if the temperature goes down before I tried any of this. However, if it doesn't come down, and the motor tests okay, it may just need a new relay. The relay is that last part you remove before testing the motor.
SOURCE:
What is the optimal temperature setting for the fridge and the freezer unit for a Siemens fridge/freezer
settingmode between 3 and 4 can be a good choice if the environment temp outside is around 14 degrees
Jan 07, 2017 | Siemens Refrigerators
Fridge temperature shown is +14. Unsure how to set temp to say +6
Usually the model number and info is on a sticker on the back of the fridge , you will more than sertainly have to move your fridge to find this info.
Feb 08, 2013 | Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
39 ltr engle fridge freezer wont shut off when at temp
hi,
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
245 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
