Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Hedge trimmer
I have a stihl hs 61 machine its from 1996, it can start in idle for a few second and then die, I have cleaned the carb and exhaust, new gas, new spark plug, is the carb bad ?
3 Suggested Answers
  • 26 Answers
SOURCE: cuts out on acceleration
if you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Posted on Feb 27, 2010
agent91
  • 2100 Answers
SOURCE: Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
Posted on May 08, 2010
Why is my Stihl HS61 not firing up?
Try cleaning out the carburettor and make sure u are using new fuel and the correct mixture
Jun 28, 2014 | Stihl Trimmer Blower Hedge Pruner...
Stihl h5 556 starts up but stalls when trigger pushed
Probably "gum" and "varnish" build-up plugging the TINY passages [called "galleries"] INSIDE your carb!!!!!
May 03, 2014 | Stihl Hedge Trimmer Throttle Trigger...
Stihl hs45 will not start but it will run after i use auto start
Check fuel lines, filter and carb... Sounds like a poor fueling issue. clean and replace carb diaphrams. Check gaskets between cylinder and carb.
Feb 23, 2014 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Hs45 backfires spits
Sounds like an over fueling issue, Try resetting the carb to its standard settings, screw both tuning screws right in ant then turn anticlockwise to the following settings H 3/4 of a turn. L 1 full turn. This should set it back to standard. If this doesn't help then it could be a carb diaphram or sticking needle.
Jul 15, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Need a new Stop Switch
You might be able to obtain a replacement switch directly from Stihl
May 06, 2013 | Stihl Hs 60, 61 Hedge Trimmer Stop Slide...
Hs45 goes dead when I throttle up
Most likely a fuel starvation problem, check and clean carb,check fuel lines for air leaks
May 29, 2012 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
26 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
