Question about Mitsubishi WS-65809 65" Rear Projection Television
Rolling screen I was dusting around the tv and when I looked back at the screen the picture was rolling and apears blue and red.
    Scholar:
  • 173 Answers
Them dang old dust mites... but seriously blue and red means you lost your green. the rolling means also your vetical sync is gone ....perhaps you hit a setup button ...take a good look and see if a button pushed in or sticking around where you dusted.to unstick you need a service man.
Posted on Aug 31, 2007
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
The picture is not clear it has a red and blue outline like 3d
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Rolling and distorted picture
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 02, 2008 | Mitsubishi VS-60707 60" Rear Projection...
No blue auto convergence when performed by menu buttons
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Tv problem
picture rolling, and vertical hight problems
May 23, 2008 | Televison & Video
Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Jan 21, 2008 | Philips 55PW9363 55" Rear Projection...
Picture rolls horizontalic and verticalic
This may have to do with your TV instead of the DVD player. If you have a red, blue and green cable running from the Philips to your TV, check the back of the TV to see if it has a slot marked "H/V". If so, purchase a 7-part component cable instead of the usual 5-part - it will have a red/green/blue, red/white, and two h/v cables.
-Tha Mp3 Doctor
Dec 27, 2007 | Philips DVDR3320 DVD Recorder/VCR
The TV Picture
The most common reason I've found for picture deterioration with projection TVs is dust build-up on the mirror. Try popping off the trim around the screen and look of several screw and retaining clips and remove them. Now remove the screen - it's just a piece of plastic. Now the mirror should be in plain view. Simply clean it thoroughly with windex and newspaper (you can also clean the back of the projection screen since you have it out). Now replace the screen and see if the picture doesn't look much brighter and clearer. This should be done perhaps every six months as TV generate a lot of static which attracts dust like a magnet. If the picture is blurry after doing this, it's possible to adjust the projector beams (there are three) to better align with the position of the screen, however I'm willing to bet this won't be necessary after the cleaning procedure. It sounds complicated, but trust me, anyone can do this. If you cannot locate any retaining clips on the front, you may have to go in from the back, in which case you'll most likely have to complete remove the mirror to clean it. It's a little more involved than the frontal method, but equally effective. It's also possible that you have a bad projector. When you get the screen off, make sure that each one is lit (the red one always looks dimmer than the green/blue ones). If one is out, try tapping on it, it might just come back to life, you never know. If not, have it replaced (usually around a $200 fix). Hope this helps you, and good luck!
Feb 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
