Question about Measuring Tools & Sensors
I need a operating manual for a cig autopak 150 mig welder
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 4 Answers
SOURCE: Need the manual for a Matco 12179 mig welder.
http://d01.megashares.com/dl/e415ff0/m12179.pdf
Posted on Dec 21, 2011
Ya240a mig welder
You can find all the century manuals and diagrams at this page:
http://www.lincolnelectric.com/en-us/support/pages/operator-manuals.aspx?q=wire+feed&type=text
Just click on it or copy and paste on your web browser.
Jan 15, 2014 | Welding Tools
I have a cig 220 I pull trigger to feed wire no wire or sounds happen welders fan is running wire isn't jammed and drive motor is working
first of all check the wiring from the machine to the torch then check that the thermal cut out light isn't illuminated, operate all switches and test on all settings, check the relay on the pcb and any contactors in there if all the above fails to find the fault then chances are a part on the pcb have failed
Oct 30, 2013 | Campbell Hausfeld Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Mig welder schematic wanted for magnum auto mig 150 turbo cheers
if you call the maker of the welder you can be sure the one they give you is right and its normaly free and faxed or mailed right to you.
Oct 25, 2009 | Welding Tools
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Where can I get a operating manual for a Craftsman 00920540 Mig Welder
Try www.partsdirect.com, this is Sears website. It may have in the parts list a part number for a operation/owner's manual.
Oct 01, 2009 | Welding Tools
Blowing fuse when trigger is operated
the wiring that you are hooked up to probably isnt strong enough, welders pull a lot of juice, you might need to re-wire your hook-up
Apr 16, 2009 | Welding Tools
Excessive wire speed on hobart ironman 250
to find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Mar 02, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Measuring Tools & Sensors Logo
167 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
