Question about Ford 8N Tractor
8 n overheated not sure what caused it but now has water in oil an low power yr 1947
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
You need to have head gasket changed that should fix that problem
Posted on Aug 19, 2013
  • montie robinson Aug 19, 2013
    that is a very good tractor easy to work on and will last for ever
What could cause engine to suddenly lose oil and produce white smoke if it not a blown gasket or cracked head?
I'm not 100% sure but I would pressure check the cylinders I suspect you are blowing oil past the rings.
Jul 15, 2014 | Chevrolet 1996 Chevrolet S10/s15/sonoma...
2001 lumina overheating
No experience with this car... But check the radiator for leaks, make sure it is not low. If possible check if the ecu is throwing codes.
Dec 29, 2013 | 2001 Chevrolet Lumina
I got a 2002 pontiac sunfire. it overheaded on me and am no tring to figure out the cause. there is oil leaking from under the car. there is a pipe with sorta like a can on it. manifild maybe? thats were...
hopfully the oil leak isnt causing overheating issue. if thats the case, your out of oil. if oil level ok, check coolant level, and if low, track down the leak source. make sure belt is intact, and water pump is spinning, etc. let me know what you find and i can help further.
Feb 14, 2013 | 2002 Pontiac Sunfire
No heat in 2003 buick lesabre but engine overheating
The first thing you need to do is check the cooling system coolant level. If it is low or empty, there is not sufficient coolant to cool the engine or to transfer through the heater core to supply the cabin with heat. Fill it up and check for leaks. Once leaks have been repaired, change the thermostat, engine oil and oil filter. If it is full, you may need to change the coolant due to its age, as well as the thermostat, engine oil and oil filter. The reason for the oil change is due to the thermal breakdown of the oil in overheating conditions. Also inspect the water pump to ensure it is being driven by the belt. You may also have air in the cooling system that is causing all your problems. Generally only happens when the cooling system is improperly filled. Make sure you add the correct mixture of coolant and water. Incorrect ratios will cause you similar problems.Coolant protects the cooling system and the water dissipates the heat.
Oct 07, 2012 | 2003 Buick LeSabre
My car overheats very easy.i can drive 1 exit on the highway and the temp goes up very fast. i dont know what it could be. there is always fluid in the reserve area and doesnt seem to be getting low or im...
COULD BE THERMOSTAT IF TOP RADIATOR HOSE IS NOT HOT AND BOTTOM RADIATOR HOSE GOING TO WATER PUMP IS HOT THE THERMOSTAT STICKING PARTIALLY CLOSE.IF TOP HOSE IS HOT THE RADIATOR,ENGINE BLOCK HEATER CORE NEED FLUSHING OUT.IF WATER PUMP WEEP HOLE LEAKING REPLACE WATER PUMP, FAULTY WATER PUMP WILL CAUSE ENGINE TO OVER HEAT.REPLACE RADIATOR CAP MAKE SURE YOU HAVE 50 / 50 MIX SOLUTION ANTIFREEZE AND WATER IN COOLANT SYSTEM. IF ALL LOOKS GOOD CHECK ENGINE OIL ON DIP STICK, IF OIL IN DIP STICK LOOK LIKE MILKSHAKE YOU HAVE BLOWED HEAD GASKET THAT WILL CAUSE ENGINE OVERHEATING WHILE DRIVING CAR IN SHORT DISTANCE AND ENGINE OVERHEATING.
Aug 16, 2011 | 1999 Oldsmobile Alero
Oil pressure or temperature can cause overheating problem?
Low oil level can cause an engine to run hot but the pressure must be extremely now for that to cause a rise in operating temperature. Naturally, if the temperature is high on the guage, the engine is already overheating, and there are a multitude of reasons why an engine could overheat, from silly things like low tyre pressures to low coolant levels and water leaks. If you like, come back with some more specific information and lets see if we can put a finger on your problem.
Mar 04, 2011 | 1998 Cadillac Catera
Water in oil how comin is a bad intake mainfould on the 4.3
A better indicator than model is the driving habits, that is warped heads are usually caused by overheating...no or low antifreeze or stuck thermostat, or friction caused by low or bad oil.
Mar 28, 2010 | 1999 Chevrolet Blazer
Overheating
If the water pump is bad it will be leaking antifreeze and you will see it dripping/running on the ground. Also, when water pumps go bad they will often...but not always...make a noise...sometimes a screeching sound. You did not mention it or that the water pump is leaking so I doubt if it is the problem. The thermostat can easily be the problem and if so is a very low cost item to replace...maybe less than ten bucks including the new gasket. Your boyfriend can install a new one easily. If that does not fix the problem of overheating then there can be many other ways the engine can be overheating. Look for a leak in the radiator. You did not mention it either so maybe that is not it.
Be sure to check all the other engine fluids...low oil...if none showing on the dipstick...can cause the engine to overheat. If you have not changed the oil and filter for the engine since forever then it is possible..but not probable...that sludge has accumulated to the point in the engine that it is overheating and even possibly causing the oil pump in the oil pan area to stop pumping oil as well as it should...but I actually doubt any of these. You could also have low transmission fluid that causes it to overheat and almost being ready to lock up causing the engine to work harder and overheating. There are many many possibilities...but the thermostat is the first thing I would do to fix it and then if it still is a problem start to look at the other areas.
Aug 21, 2009 | 1999 Chrysler Cirrus
Engine overheat, A/C shut off, fan hot
Chances are that your engine is ok. Bad engine overheating can seize the engine. Less extensive overheating can crack the engine especially the cylinder head and lead to power loss or mixing of water and engine oil. If water is mixing with oil, the oil looks milky. If your car is not losing power and the oil looks normal then chances are that there was no damage to your engine.
Just make sure that whatever caused the overheating in the first place is sorted out - perhaps the radiator flushing resolved the cause of the overheating.
Jul 25, 2009 | Hyundai Motor 2002 Elantra
My husband and I have a 1995 Oldsmobile Aurora. We just changed the oil about 2 weeks ago. He checked the fluids earlier and the oil was low and the car is running hot. What could be causing this?
If you changed the oil filter at the same time check that it hasnt come loose and leaked some oil though there would be signs of that where the car site. If it is overheating check your water as well.
Also check the oil for water and the water for oil as you will want to make sure that you havent done any head damage or blown the gasket.
Jun 28, 2009 | 1995 Oldsmobile Aurora
Ford 8N Tractor Logo
95 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
