I HAVE AN INSIGNIA TABLET AND THE RECEPTACLE WHERE THE CHARGER PLUGS INTO HAS BEEN SLIGHTLY DAMAGED. IT WILL NOT CHARGE. HOW CAN I FIX THE RECEPTACLE?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
It is better to take it to a local shop and have it changed to prevent from further unfixable damages
Posted on Aug 01, 2013
What do i do if the charger part that's inside the tablet that the charge cord plugs into breaks
check ebay for charge port parts for your particular tablet.
if parts are available open up tablet and change the broken charge port.
Jan 27, 2018 | Tablets & eReaders
My charger will not stay on when i plug itin to tablrt
If you have a voltage meter, check that the voltage reads what is printed on the label's "output voltage".
Try a different charger if you have one or borrow from a friend.
It's most likely a bad charger.
Purchase one from Amazon, if it turns out that isn't the problem, then you can just return it.
Sep 08, 2017 | Computers & Internet
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My Insignia WiFi Windows 8" Tablet will not charge please help
If it's under warranty, take it back.
Also check to see if there was a recall as the batteries may be unreliable.
If you know someone else who has one, check with their charger - your charger may have stopped working.
Jan 06, 2015 | Tablets & eReaders
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
Mar 12, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
Where can I get another charger for my insignia tablet
Order it from Best Buy. Insignia is their house brand.
Jan 10, 2014 | Tablets & eReaders
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
How do u charge an irulu tablet, didnt get a charger with it
I got my tablet with a charger but after some time it got damaged.. NOW I USE THE MINI-USB cable to charge it.. you can use an adaptor like the one that comes with the Samsung galaxy cellphone and use the mini usb cable with it.. Hope you understand my mess.. good look..
Dec 13, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
Televison & Video Logo
Top Televison & Video Experts
