Question about Ford 8N Tractor
Overheated once an since then have water in oil
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Head gasket needs to be replaced , ford 8n is a very good tractor and will last a long if you take good care of it
Posted on Aug 19, 2013
My 2004 vitara over heated once n now I have to keep filling it up with water, where is it all going?? Their are no water leaks on the ground.
Perhaps when it overheated, it cracked the block. The water could going into the engine's oil compartment. (Not good!)
Apr 17, 2016 | Cars & Trucks
Check list for answers to my Montero overheating...
Methods to trouble shoot
(1) check thermostat device. if thermostat is stuck - not working half the water used in cooling system is missing once engine heats up which can lead to over heating. (may need mechanic to check this)
(2) check radiator has water in it . if it is low there may be a leak in cooling system somewhere check rubber hose and radiator are not leaking.
(3) check fan belt is engaging fan in front of radiator
(4) if electric fan check if fan activates once car has heated up
(5) check oil level of engine on dip stick. If low oil add some oil and re check oil dip stick. DO NOT PUT whole oil pack in (don't laugh I know someone who did this and has to go to mechanic and get oil removed)
(6) if rubber hoses blow off connectors then you may have a broken head gasket seal. A pressure test of the radiator will confirm this.
(7) Possible water pump failure. Check by taking cap off radiator and run engine see if water is flowing in radiator and test if water is heating up in the radiator. Remember to put cap back on radiator when finishing test.
(8) check if bubbles or oil are in radiator water this could indicate a blown head gasket problem also.
Oct 20, 2014 | Mitsubishi Montero Cars & Trucks
No heat in 2003 buick lesabre but engine overheating
The first thing you need to do is check the cooling system coolant level. If it is low or empty, there is not sufficient coolant to cool the engine or to transfer through the heater core to supply the cabin with heat. Fill it up and check for leaks. Once leaks have been repaired, change the thermostat, engine oil and oil filter. If it is full, you may need to change the coolant due to its age, as well as the thermostat, engine oil and oil filter. The reason for the oil change is due to the thermal breakdown of the oil in overheating conditions. Also inspect the water pump to ensure it is being driven by the belt. You may also have air in the cooling system that is causing all your problems. Generally only happens when the cooling system is improperly filled. Make sure you add the correct mixture of coolant and water. Incorrect ratios will cause you similar problems.Coolant protects the cooling system and the water dissipates the heat.
Oct 07, 2012 | 2003 Buick LeSabre
Truck overheated, coolant in oil....any hope?
Have a mechanic look at it and replace the head gasket if that is the problem. Some problems have to be faced directly.
If it sounds too good to be true it very likely is.
If you live in Florida, you may have the right to shoot the truck.
Sep 13, 2012 | 1991 Toyota Pickup
I am getting an engine system failure light coming out on my 2005 ford focus. The first day I checked oil and water. The oil was slightly low and I topped up. The water appeared to be overheating and I...
Sounds to me like you are having a cooling system problem, if water is boiling in the tank or radiator then the engine is overheating. If you have not flushed the cooling system, it would be a good idea to do so. Also you need to test the cooling system at idle and see if the engine will maintain normal temperature, without overheating. Overheating can be caused by plugged or restricted radiator, hoses, or the thermostat, also check the operation of the electric cooling fan. Once you solve the overheating you light should stay off. If you do not solve the overheating soon, the engine will suffer major damage, so check it out very soon. Hope this helps, let me know.
Aug 04, 2010 | 2000 Ford Focus
My car is overheating. I just replaced thermostat and recently replaced the water pump. I checked for water leaking but dont see any. What could it possibly be
If the thermostat and pump have been replaced, it's most likely the radiator. They corrode after time. Try flushing the antifreeze (not just draining and refilling it, but flush the system with clear water.) Most auto stores, Walmart, etc. carry the flush kit for very little $$. Once it's flushed, refill the system with the correct ratio of antifreeze.
If the problem persists, then it's most likely gunk in the radiator. Auto shops can boil them clean.
Short of all of the above, overheating can also be caused by a cracked cylinder head. If it overheated too bad at any point, it can crack the head and will continue to overheat regularly. Check for antifreeze in the oil. If there "is" antifreeze or water in the oil, the head is most likely shot (and yes, it will still run that way).
Jan 25, 2010 | 1987 Cadillac Brougham
2004 ford taurus. Its not overheating but there
Did you recently have a transmission fixed?
If so it sound like the drive plate bolts were not applied with Loctite.
Maybe a oil viscosity problem if not a transmission job.
Jun 16, 2009 | 2004 Ford Taurus
'95 MUSTANG IS OVERHEATING
bad headgasket = water in oil (milky) or oil in water (foamy I think).
but yea, ah... I had a Ford once. My experience is that once something like this starts the only thing you can do to repair it is to buy a japanese car. lol
Mar 06, 2009 | 1996 Ford Explorer
Overheating
I think you have made a correct diagnosis. The loss of power and water from exhaust all point that way.
Oct 20, 2008 | 1999 Jeep Cherokee
Ford 8N Tractor Logo
127 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
