Question about Exercise & Fitness
Need power adapter for bodysculpture bm1505 - Exercise & Fitness
Body sculpture BM1505 is it possible to purchase the fixing items for the handle
Depending on how old the unit is. There are places where you can buy parts or you can visit www.body--sculpture.com and email them for the parts you need. Otherwise, if you're lucky someone is getting rid of his and you can rescue it for parts. Try the company first.
Dec 28, 2014 | Exercise & Fitness
Power slimmer bm1505 instruction booklet
hi..
my sister has given me her body sculpter power slim bm1505... but i have discovered there is no remote or cable ( lost when she moved).. i am enquiring to see if i can purchase the cable and remote from a retailer and how much it would cost..
if you can help i would be a very soon to be slimmer lady ha..
thanks in advance
jess
Feb 04, 2014 | Horizon Fitness Treadmill Running Machine...
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
No power at forward poser adapters
did you check the fuse (under the hood) to see if it needs replacing? I had a dime roll into my power adapter which in turn blew the fuse. It is a separate fuse than for the rear power socket(s). Check the owners manual for the proper location for the power adapter (front). Remember to check the power adapter for any metal objects before changing the fuse.
Jan 05, 2009 | 2006 Buick Rendezvous
POWER ADAPTER
LOST POWER ADAPTER NEED TO PURCHASE NEW ONE
Apr 30, 2008 | TruTech PVS12701 Portable DVD Player
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
