Question about Acer Aspire Computers & Internet
Acer aspire 5551-2805 won't turn on. Sounds like it's starting, then turns off. Screen stays black.
sandrew
  • 2961 Answers
SOURCE: Acer Aspire 3100 boot up problem
unless it is something more serious, first keep pressing F8 when you turn on the notebook and it should enter safe mode. When in safe mode select the operating system that is highlighted and then a screen will appear with options, one being 'Last Known good Configuration', highlight this and press enter. The system will reboot and start again in windows as normal hopefully. If you are not able to get a screen showing in safe mode there is something more serious wrong and it could be hard drive fault or motherboard, but if you can see the disc drive light flickering the system is loading and you may have a graphical fault.
Posted on Aug 10, 2007
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
kyo_ajis
  • 68 Answers
SOURCE: Blank Screen Acer Aspire 5920
im afraid that your screen is broken, but try to move the screen foward and backward littlebit, my friend also have the same problems and only by contact local support using his warranty the problems fix, you may open your laptop to see if something wrong with the wire but i think its not practically good.
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: ACER ASPIRE 5610z BLACK SCREEN
FIX:
I have an acer aspire 5520G and i can relate all too well. It worked fine for about 3weeks (from brand new!!) then one day the screen went blank while trying to boot. I managed to fix it and it worked fine for almost 2years, untill i went to sell it and encoutered the problem again.
The Fix: this is the fix that worked for me; firstly the problem; this seems to be a big problem with acers for some reason, and there are a few variations or confusions about it when people describe their fault. My fault is that when my laptop is off, i press the power button and the green light comes on, a fan starts up and there is hope, but then the fan changes speed slightly and it stays like that indefinatley, without the screen having ever come on, and i mean the computer is virtually dead except the power light and fan, you cannot press ctrl-alt-del or see the screen from an angle or with a torch. the only thing you can do is hold the power button and force a shutdown, so some deep seeded hardware is still working, but it seems the display never starts and the BIOS never loads.
My first fix - i managed to start my computer by pressing the power button, then as fast as i can (hold function button) repeatadly press F5 and F6 ie. with the function button held you are pressing [Black out screen/Restore Screen] and [Switch Monitors]. this usually starts my laptop on the first or second attempt. The first time i did this i was playing around with external monitor cables and connections, and switching monitors and the problem spontaneously fixed itself as mysteriously as it had arrived.
Second time was extremely frustrating, i could still load my computer by pressing F5 and F6 combos but could not get it to become self sufficent. I upgraded my BIOS with the Flash Updater from acer (i found it on the net) and after the second boot attempt, windows vista installed some memory drivers, and the problem was resolved.
if this hadnt worked i would have tried the memory battery fix as above, as my problem definatly seemed bios related.
Hope this helps someone from loosing their hair.
Posted on May 11, 2009
  • 89 Answers
SOURCE: acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Posted on Aug 02, 2009
Why won't my laptop boot?
sounds like an unhappy computer try this
turn off computer
press F8 and turn power on at same time
should open to SAFE Mode
run that for a bit then restart
let me know how that works for you
May 22, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My laptop wont turn on, the green light apears when I press the on botton and it sounds asif it's starting up, but then nothing happens, the screen stays black ?
If you have a desktop computer ,try connecting monitor cable to laptop,u may get the display.
It sounds like ur lcd or the inverter board has a problem.
Nov 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Aspire One PC Notebook: My acer one aspire turns on but screen stays black...
Try this for the black screen of death problem...
Here’s what you need:
  1. USB Memory stick (as low as 128mb)
  2. Another PC with a net connection
  3. WinZip, WinRAR, or some other program that can extract zip files.
  4. A quick visit towww.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on.
And here’s what you do:
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110/150/751)
  2. Click on the tab on the download area that reads ‘BIOS’ even if it looks like you can’t click on it (their site design grays it out but it’s there) and download the BIOS file numbered 3310 (it might have changed version recently but do it) and don’t worry, you can trust this file, as it’s from Acer directly.
  3. Extract the zip once downloaded and find in the DOS folder the files ‘flashit.exe’ and 3310.fd
  4. When you’s ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  5. Put the USB in the Aspire One and hold the keys ‘FN’ (function) and ‘Esc’ (escape) and keep them held when you turn the laptop on
  6. Watch the power button and when it starts flashing, press it once (DO NOT DO ANYTHING ELSE)
  7. You should notice the USB (if it has a light) blinking as well… The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
It took my three times but this IS the proper solution! I am now very happy with my Aspire One that still works!
May 16, 2010 | Acer Aspire One PC Notebook
'When i turn the acer aspire one on i get a black error 17
you should reinstall windows. sounds like a virus
Dec 28, 2009 | Acer Aspire One PC Notebook
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Acer Aspire 5100 Notebook
Acer Aspire (1414) screen stays black when started
It's look like your laptop have a problem called "NO POST".
motherboard, cpu or memory can cause this problem.
To diagnose it, reseat your memory first and after that turn it on.
if it still no post.
use only 1 memory and turn it on, if still same,
Try to move your memory and seated to different slot and turn it on. if it still same, it's mean your motherboard/cpu is bad.
good luck
Jul 11, 2008 | Acer Aspire 1414 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
