Question about Sanyo SR-4910M Compact Refrigerator
Ice or water on back of inside compartment
If I put the control on 3, ice forms on the back of the compartment. If I set it back (even to about 2.5), there is water on the back of the comparment and the food is not cold. What is causing this? How do I fix it?
  • DB356 Sep 05, 2007
    Was a good suggestion, I tried it. An air leak is not my problem. Thanks.
  • Sparta Mar 27, 2008
    Fridge freezes even when it's at minimum...we have been keeping it just below minimum but it froze over the weekend and all the cans inside "expoded".
  • 291 Answers
Might check the door seal...take a dollar bill and close the door on it... should feel light drag on the bill.. try like that all around gasket see if any spots with out drag on bill.. might have air leak
Posted on Sep 02, 2007
  • Mike Johnson
    Mike Johnson Sep 06, 2007
    check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing,
    check vents in refrig. make sure no blockage, freezer control should be in the middle setting,
    you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
SOURCE:
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Ice billed up in and around ice dispencer even when ice maker is off.
You don't mention a brand or model. All ice makers and chilled water dispensers must have a household water supply. This is controlled by water valves (much like a washing machine) that turns the water flow on and off as needed. If you've cleaned out the ice maker compartment, cleared away all ice build up and the icing problem recurs (usually over a period of days) then the water valve is leaking which lets water dribble into the ice maker compartment forming the ice. You can prove this by shutting off the water supply to the refrigerator (or even disconnecting it.) A new water valve should solve the problem.
Nov 01, 2016 | Refrigerators
Intermittant ice making
When you see this happen can you feel the bottom of the ice maker to see if hot? What is the correct model number? I am trying to understand if it is the ice maker heating element is stuck on while heating the ice maker to release the cubes or if the water control valve is allowing the water to come in through the fill tube like a leaking faucet. Thanks, John Tripp Appliance 911
6aa070b8-d84c-4116-a3d3-21bc4d340b93.jpg PSS26MSRSS)?
Jan 27, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work.model kbfa25erss01
Hi and welcome to FixYa, I am Kelly.
Often when ice-makers stop working the real problem is that the freezer is not cold enough (It must be 14-16F for the icemaker thermostat to cycle) Check for signs of ice or substantial frost in the back of the unit / evaporator coil area. If you have ice / frost in this area you should do a manual defrost by unplugging the unit and directing an external fan into the freezer compartment for about 2 hours while it makes a water mess that will need to be tended too. Once the 2 hour thawing is complete wipe up the excess water and return the unit to normal service. If the problem was caused by excess ice it will operate normall for 2 - 3 days before ice production slows or stops totally. Should the manual defrosting correct the icemaker problem you most likely have and automatic defrost problem in the form of a problem with one of these 3 components:
1. Defrost control
2. Defrost heating element
3. Defrost thermostat
Having said all of that... You can use this manual to check out your icemaker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Make sure to test the coils on the inlet water valve for continuity. If one of the coils is open *** must be replaced. The inlet water valve is NOT repairable.
Your water valve can be found here:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-water-inlet-valve-item-number-ap4080917.aspx
Here is another link on how to test out the icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The ice-maker thermostat must be at or belw 16 F for the above tests to work.
NOTE the freezer door LIGHT switch must be taped down also.
Before you get too deep into troubleshooting checkout the freezer door light switch first. If the switch is bad the freezer compartment light will not work and the ice-maker also will not work.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | KitchenAid Refrigerators
The freezer keeps freezing the coil in the back of the freezer how do I put it on defrost
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Take care....
Aug 15, 2010 | Roper Refrigerators
I have a whirlpool fridge with the freezer on top. The ice maker is not making ice quickly. How can I fix this?
Good day,
As a general rule refrigerator ice makers don't really make ice cubes very fast.
Things that could increase the production are.
1. Set the freezer to a colder setting. That control is usually on a whirlpool is called an air control.
2. Setting the refrigerator control colder, while also help since setting it to a colder setting will actually make both compartments colder.
3. The ice maker produces ice when it's internal thermostat reaches approx. 14 degrees.
You have no control of that function.
4. If the cubes are on the small side, the water valve on the back bottom of the machine may need to be replaced.
5. Along that same line, the water supply line from the house and it's fittings could be starting to restrict, not supplying enough water pressure.
The line, unless plastic, and the valve would need either be removed and cleaned or replaced with new.
Dec 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The air vent between my freezer compartment and fresh food compartment below is frozen over and as a result, the fresh foo d compartment gets too warm. I have a Frigidaire refrigerator, model FRT8B5EWA....
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 29, 2009 | Frigidaire FRT8B5EW 30" 18.2 Cu. Ft. Top...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice is forming in the bottom of the freezer compartment, and water forms under the fridge freezer. Also the comperssor does not always respond to the freezer setting when the stat is turned...
compressor may not start for quite a time even if you change the stat setting. this is deliberate.
ice on floor of the freezer is caused by the drain being blocked - probably with ice. remove the back panel inside the freezer and melt the ice off with a hairdryer. you will have to clear the drain itself with hot water - needs a bit of patience.
this can just happen with time but you may have a fault on the defrost system which is causing it
Jun 25, 2008 | Admiral Refrigerators
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Sanyo SR-4910M Compact Refrigerator Logo
140 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Bailey's...
Bailey's...
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
