Gbc heatseal h400
Where can i get a replacement motor for the gbc heatseal h400
3 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
How do I put a GBC Heatseal H425 laminator back together?
You might contact GBC directly and request an assembly diagram
Jul 14, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Is there a schematic diagram for heatseal ultima 65 I need one.
not that I am aware of, the maint manual has a theory of operation block diagram, but no schematics.
Jan 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
27 people viewed this question
jasbo
jasbo
