Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
REFRIGERATOR DOES NOT COOL
DISPLAY SHOWS EC ERROR CODE AND REFRIGERATOR DOES NOT COOL
  • LEONTE Sep 03, 2007
    03 EC
    03 EC
  • 175 Answers
What is the EC #? That will tell you where to look. It should cycle EC then say a 2 digit number. Is the frideg cooling at all? Also check the back wall down the left side and see if there is any ice there. Last, feel around the door opening where the door seal meets the cabinet and see if the cabinet is hot. If it is, check to see that your condeser up top is clean and that the fan up there is running when either one of the compressors is running. Any ore info you could give would be helpful in diagnosing your problem. post back and maybe we can figger it out. Good Luck!
Posted on Sep 01, 2007
SOURCE:
EC error code on my voltas ac model 245dye 2 ton ac please help 2016
In my voltas 1.5 ton display shows ec . And no cooling is coming . Wat to do?
Apr 17, 2017 | Heating & Cooling
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
What is wrong when the display shows EC and the run light flashes 7 times , then stops flashing for 4 seconds , then starts flashing 7 times over and over ?
THE "EC" CODE IS A LEAK DETECTION CODE,, SHOWING THAT THE FREON LEVEL IS LOW, AND YOU COULD HAVE A LEAK,,
? 7 times X EC Refrigerant leakage detection It is time for a service tech
Nov 20, 2015 | Midea 18,000 Btu 17 SEER Inverter Mini...
My midea ac showing EC error why it will apperas?
Apr 24, 2015 | Midea Heating & Cooling
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
183 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
