Question about Kohler K-6356-7 Avatar Single Control Kitchen Sink Faucet, Black Black
What is causing kohler avatar faucet 6353 leaking at base on countertop
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
bearsfan7538
  • 119 Answers
SOURCE: kohler k19774-4 faucet single control valve is
You need to call 1-800-4-KOHLER and get a replacement cartridge
Posted on Nov 15, 2009
  • 5 Answers
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Posted on Dec 27, 2009
SOURCE: I have a kohler a112.181
Having the same problem and just found the spec sheet. Going to try to repair today. Hope this helps!
http://www.us.kohler.com/onlinecatalog/pdf/1013943_4.pdf
Posted on Aug 06, 2011
How do I replace a cartridge for kohler bancroft sink faucet?
kohler bancroft is the sink manufacturer, not the faucet mfgr. do you have a clue what faucet mfgr it might be?
Jan 14, 2018 | Kohler K-10577-4-SN Bancroft Widespread...
Can't unscrew the threaded nut which tightens the Kohler Clairette faucet to the countertop. Have sprayed with liquid wrench to no avail. Can't get a good hold on it and am also afraid to crack the...
Those so-called dress nuts are not easy to remove because there is no way to get a grip. Try cleaning the nut thoroughly to remove any Liquid Wrench residue then use one of those rubber or plastic jar openers and the Armstrong removal technique to loosen the nut. You might also tap the nut with a rubber mallet or a hammer wrapped in a towel to loosen it. Worst case, you may have to partially remove the faucet assembly to gain better access to the nut and remove it. Be sure to protect the granite countertop while doing any work
Sep 08, 2013 | Kohler Plumbing
I changed out my Kohler shower diverter cartridge because it was leaking after doing so when you open any faucet in the house it will leak the more faucet you turn on the faster it leaks. The lady plumber...
did your old diverter have a shut off knob on it? if so you may have not noticed it leaking, -what causes that is the existing shower faucet may have been mounted to high from the spout below -or the pipe going down from existing fixture to the tub faucet spout pipe may not be at least 3/4", -if its 1/2" it will always do that
Sep 06, 2017 | Kohler Home
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Kohler K-6356-7 Avatar Single Control Kitchen Sink Faucet, Black Black Logo
136 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
