Question about Waring Pro IC70 Professional Ice Crusher
Blades stripped on waring pro ic70 crusher - Waring Pro IC70 Professional Ice Crusher
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Where can I get my
Hello, dmiller
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
What to repair for 110v device that burnt due to 220v
Garbage, not repairable.
Don't use step-down travel adapters, but dual use appliances/
Apr 11, 2016 | Waring Pro IC70 Professional Ice Crusher
Why can't coupler turn blade?
Drive shaft may be stripped
Dec 27, 2015 | Waring RB70 Blender
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
Kenwood instructions sb200 how to put ice crusher blade on?
GO TO www.retrevo.com or www. fitness.manualsonline.com and get it.
God bless you
Nov 04, 2013 | Kenwood Hb724 Triblade Hand Blender
What material is the The Hamilton Beach Wave Crusher 8 Speed Blender 1 EA58142 made of?
The The Hamilton Beach Wave Crusher 8 Speed Blender 1 EA58142 is made of patented stainless steel Ice Sabre blades.
Feb 07, 2013 | Hamilton Beach Wave Crusher 8 Speed...
Where can I get my Waring Pro Ice crusher fixed.
Hello, dmiller
Thanks, Mike
Sep 04, 2011 | Waring IC70 Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Waring Pro IC70 Professional Ice Crusher Logo
62 people viewed this question
Top Waring Blenders Experts
Darial Jr Lasaria
Darial Jr Lasaria
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
