Question about Maytag Washing Machines
How do I undo control panel on my mvwc500vw1 washer
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Control Locked Light on washer? How do I undo?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Posted on Jan 21, 2010
How do I get to the motor control board
Remove front panel by undoing screws that hold door on, pull top of panel forward, lift up & remove. Motor control board is on the Lower rhs.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
How to install presure switch
Hi.
The pressure switch is located behind the control panel. Its unction is determining the level of water in the washer.The switch looks like a round shaped plastic switch connected to wires and to a long thin rubber hose. To replace the switch disconnect power. Undo the screws holding the control assembly. Remove control assembly cover. Disconnect wires from switch and undo the screw holding the switch. Pull out the rubber hose from the tub and perform operations in reverse order to install the new part.
The switch is part nr.4 in diagram below. Click on the picture to enlarge:
Jul 07, 2011 | Maytag MTW5700TQ Top Load Washer
Side wall out of slot.How do i remove top to put sides in place?
Undo screws at the sides of the control panel. flip control panel back and remove big brass clips that hold back to housing the top does not need to come off. http://www.youtube.com/watch?v=vogysB7XOc8 reply !!!
Dec 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove the front part of my kenmore washer? its a top loader
If the front is a separate panel then it is made by ge and just insert a putty knife between the top and front panel a few in in from either side . Pull out and up to remove. If the front is part of the case then it is a whirlpool so you must take out the two screws holding the control panel down( either in the front corners or the rear corners of the end caps on the panel or under the covers for the end caps removes by prying forward) lean back control panel undo lid switch wires and remove two brass coloured spring clips holding case to back. Remove by tilting forward and pulling out .
Dec 07, 2010 | Kenmore 22422 Top Load Washer
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace lid switch
you should either have screw at both sides on rear of control panel. if not you have tension clamps at right and left side at bottom of control panel in front. use putty knife. flip control panel back. undo lid switch harness. lift lid up and pull lid switch out. remove 5/16 ground screw first
Jun 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Aug 29, 2008 | Washing Machines
Washer not spin cycle or Drain
It maybe the timer has a fault in it. You should have a spin cycle on the other side try useing the drain and spin on that side. If that doesn't work replace the timer. Also if you are able to, undo the control panel should only be 3 screws on the back and make sure no wires have dropped off the timer panel. But please unplug it first
Jun 29, 2008 | Whirlpool LBR4132JQ Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
