Kingston 2 GB USB Hard Drive
Problem for Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston DataTraveler2GB
By gyan on Aug 31, 2007
my pan drive it is working properly but today it is not detect in my computer and as well as iam traying another computer also it is not detect what can i do plz suggest. i dont know about warenty detail also plz suggest how to check my warenty.
Same Problem
Jun 02, 2008
-   I have XP installed. Kingston DataTraveler 500MB works good, but the 2GB my PC don't recognize it. A message like this appears: "cannot find volume information ; it can happen in USB devices or 1394 on a W 2000 machine".
Please help me. Thanks.-   peterga
May 31, 2008
-   my pendrive is not deecting it is kingston 4gb on win xp computer-   narasi
May 04, 2008
-   i need the driver for kingston 2gb Data travellor to run in win98se-   Guest
Apr 16, 2008
-   i have transcend 2 gb usb drive and the problem is it is detected some computer and not detected in other computer but other pen drive of same model is detected in that computer-   Guest
Nov 22, 2007
-   My computer do not identify my pen drive (DataTraveler2GB). I need
to install the softwear of instalatation in my computer, but I don't have this
softwear. Coul you help me?
Tks
Mauricio from Brazil-   Sarri
Best Solution
posted on Sep 01, 2007
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3780 votes
I couldn't get any software utility or firmware updater/repair from the Kingston site, however, I have tried the HP Drive Key Boot Utility and it works even for Kingston and JetFlash. The bad side is it completely erases the contents of the USB drive.
Should you want to venture and try it, it is available for download at http://h18000.www1.hp.com/support/files/...
file name is cp006049.exe
Hope this be of some help/idea. Post back how things are or should you need further information.
Good luck and kind regards.
Was this helpful?
Yes
No
Solution #2
posted on Oct 01, 2009
Not Rated)
krajaneesha
Rank: Apprentice
Rating: 0%, 0 votes
windows unable to format my 32Gb Data Traveller
Was this helpful?
Yes
No
Solution #3
posted on Mar 28, 2009
Not Rated)
peterga
Rank: Apprentice
Rating: 0%, 0 votes
I got the solution in http://www.everythingusb.com/forums/showthread.php?threadid=9488
If you have ever loaded Daemon Tools (it appears the newer versions are the problem) and your USB Mass Storage Drives will not show up in Explorer then your problem is a file called sptd.sys. It resides in either "system32" or "system32\drivers". You can simply rename it or delete it. Restart and Wahlah!!
I renamed sptd.sys in c\windows\system32\sptd.sys to sptdxxx.sys and it worked fine, but to open Daemon Tools I must revert any time.
Was this helpful?
Yes
No
Solution #4
posted on Mar 27, 2009
Not Rated)
Rusva_352
Rank: Apprentice
Rating: 0%, 0 votes
my usb is not dectacting to the system
Was this helpful?
Yes
No
Solution #5
posted on Apr 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
in my kingston 2gb new folder.exe is created n after this i want 2 format it but it is not formated
Popular Solutions for Kingston 2 GB USB Hard Drive
Questions and Unsolved Problems for Kingston 2 GB USB Hard Drive
Do you recommend Kingston (DTIU3/2GB) 2 GB USB Hard Drive?
Answer
Answer
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I... (More)
Answer
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you... (More)
Answer
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted.... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 19, 2007
my pen driver is not detecting , shall you please send any suggesstion regarding this.......
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kingston 2 GB USB Hard Drive:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14881
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
