Question about Garden
Js63my js63c will turn to the left but not to the right, the right rear wheel is turning but not the left. The front swivel wheels are ok. Do I have a trans problem?
  • 142 Answers
SOURCE: front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
Posted on Sep 20, 2008
  • 24 Answers
SOURCE: yazoo rider left side pump stalls when cold
Im not a yazoo dealer but I can tell you some easy things to check, If you have a reservoir tank with an oil filter in line, there are two kinds of hoses suction and return if there is an air leak on a suction line it may not show an oil leak but it will put air into the pump making it week most of the time its cheap
hose clamps or loose hydro filter .
A lot of hydro use a gear case bolted right to the pump without any hoses , but that not what we call commercial .
good luck
Posted on Feb 20, 2009
SOURCE: Rear end in 1999 chevy 1500 binds on turns
well i had the same problem everyone told me the clutches in the rearend were sticking making it stick in positive traction (only your passanger side rear wheel pulls unless you start spinning then a type of clutch engages the other side so you have traction then when you stop spinning it disengages it should never be engaged if your on pavment) now you can do what i did listen to everyone when they tell you its normal or you can take it to someone with experience now and save yourself some money cause it will start popping then it will get some viberation then next it will break the clutches and when that happens you will have to replace the pinion,ring,and the spider gears as well as the clutches.make sure you have pleanty oil in rearend if you dont add the limited slip conditioner it might free clutches up but if i had it to do over id put it in the shop or stop driving it before i broke something hope this helped
Posted on Mar 30, 2009
SOURCE: cant seem to get the front wheel to stay on swivel
I have the same stroller, and it's driving me nuts!
I saw this on a different post:
noavatar_s.gif sausagegirly
Rank: Apprentice
Rating: 100%, 1 votes
hi we had the same problem with our p&t sports buggy, brand new out of the box the front wheel kept locking, driving me mad! we contacted our supplier, kiddicare.com, who were extremely helpful and sent out a "front wheel swivel/fixed catch (screw fixing)" - it has WORKED WONDERS! the buggy is now smooth and easy to handle. you have to remove the old catch pin which can be a bit of a fiddle (when we got the old pin out it was a rivet fixing and very rusty) but only took us 10 minutes. highly recommended if you can get hold of one of these new screw fix pins, which have obviously been brought out to fix a common fault which p&t can't be bothered to recall lots of buggies and fix themselves...... ;)"
I've made contact with the store I've bought my e3 from, now, waiting to hear from them about this 'fix screw'. hopefully it'll solve our probs!
Good luck
Posted on Jun 22, 2009
  • 5 Answers
SOURCE: JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
Posted on Jun 25, 2009
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
Chicco 3WD Tech rear wheel needed
Try jogging stroller its easy to Swiveling front wheel & maneuverability. Locks forward for increased stability when jogging or if the terrain turns tough.
Mar 06, 2013 | Chicco 3WD Tech - Canarie Stroller
Jane Rider front wheel swivel problem....they get stuck.
We have had exactly the same problem. We took the pram back to where we purchased it from and got the pram fully serviced, the back tyres were changed for a better quality all terrain one, and the front tyres were also changed with new bearings fitted. It works as good as new now, however I still think this is only a temporary solution... Interestingly we have only used the pram (from new) for just four months before the tyres completely deteriorated and we found the manoeuvrability a major problem.
Jun 28, 2012 | Jane Rider Pushchair in Buganvila
My stroller wheels wont swivel only going in right directiin dey work when im driving it n try to turn dey wont swivel but when I go in right direction dey drive perfect
The front wheels clip off. Take them off and wash in hot soapy water then rinse in fresh water. Clean the metal pin the wheels clip to and swivel on with a rag. A light spray of silicon lubricant will help. The usual Bee problem is they swivel too easily and people fit rubber washers on the metal pin to dampen it.
Sep 22, 2011 | Bugaboo Bee Standard Stroller
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Babyjogger city elite front wheel shakes
You need to put more weight on the front of the stroller. The wheel is shaking because it's able to swivel....
Apr 12, 2010 | Baby Jogger City Series Single Stroller
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
Steering wheel lock
make sure you turn the ignition key at least a bit first
Nov 25, 2009 | 2002 Dodge Durango
Road noise from right front wheel, louder at higher speeds, worse when turning left
front right wheel bearing will cost you 80$ might want to check the left side bearing too.
Jul 30, 2008 | 2002 Pontiac Aztek
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
