No pathologic enhancement with contrast - Computers & Internet
I am looking for base only for Sharp TV #LC65D93U. WHere I can find one?
Hello, the part # is CDAI-A368WJ01, and it's $233.00 everywhere I looked. If you will message me back on Tuesday, I'll see if I can locate a used on....tks
Sep 01, 2014 | Sharp LC-65D93U Refurbished AQUOS 1080p 65...
Which lens color is the best?
Lens color is a personal choice and doesn't affect how well sunglass lenses protect your eyes from UV light. Gray and brown are popular because they distort color perception the least.
Athletes often prefer other tints for their contrast-enhancing properties. For example, yellow lenses are popular with skiers and target shooters because they work well in low light, reduce haze and increase contrast for a sharper image.
Nov 07, 2010 | Clothing Accessories
Is it a good buy
This Sharp 1080p LCD HDTV with 120Hz fine motion enhanced provides a slim, versatile high-definition television solution with a distinctive design. Features a high-performance ASV LCD panel for high brightness, spectral contrast engine UD for high contrast ratio, low-reflection glare protection and wide viewing angles.....GO AHEAD
Nov 05, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
My Dell E173FP adjusts its own brightness I was hoping I could fix this problem myself but I am willing to spend some money to get it fixed the only other solution possibilities I have gotten is that I...
Sounds like dynamic contrast. Have you looked through the settings on your monitor to disable any automatic functions such as dynamic contrast enhancement?
Oct 19, 2009 | Dell E173FP 17" LCD Monitor
How to fix and enhance photos?
go to gimp.org and download the gimp programme,its very good and free
Mar 11, 2009 | Computers & Internet
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Lines on tv
Try these:
Contrast: 53 Brightness: 56 Color: 44 Tint: 2 Sharpness: 2
DNR: Off
Active control: Off
Feb 11, 2009 | Philips 42PFL3603D 42 in. LCD TV
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
