Question about M-Audio BX5a Speaker
I have a BX8a that has suddenly started making very loud noises of all frequencies when turned on. This happens even with the volume all the way down and no audio cable connected to it. I am wondering if anyone has ever experienced anything of this nature with a powered speaker before. I am going to attempt to repair it myself but I am hoping someone could direct me where I should start. My best guess as to why this happened is that I was using a power conditioner to power them on and off opposed to using the power switch on the back of the speakers. I have read that this can be damaging to them with the sudden surge of power. Any help would be much appreciated.
2002 Honda Accord makes loud exhaust sounding noise
The O2 sensor could have come loose, also look around the area of the O2 sensor for any cracks in the pipe, look for black coloring on the pipe, this will indicate the leak area. As exhaust smoke is blackish and will coat the leaking area.
Jun 28, 2014 | 2002 Honda Accord
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
Excessive noise in my speakers
usually, it is background noise. Scratchy background noise. Gets worse the louder I turn up the volume. I ran a test on all the channels and it seemed to be the subwoofer channel. I've unpluged the subwoofer but that didn't help. I have also noticed that my receiver doesn't turn up nearly as loud as it used. I usually watch DVDs at a volume level of about 15 on my Denon and that's quite loud. But now, 15 isn't that loud at all. I went to Best Buy where I bought all of this equipment and they immediatly told me it was suge protector issue and wanted to sell me a high-end surge protector. Perhaps they are right but not sure why it began rather suddenly. Probably not helping you much.
Apr 07, 2010 | Denon AVR-2805 Receiver
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Motor noise coming out of speakers
you may have a short in one of your speaker wires, or your antania
Aug 07, 2009 | 1993 Buick Century
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
Sep 13, 2008 | Fusion FEW12PK Car Subwoofer
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
M-Audio BX5a Speaker Logo
43 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
