Question about JVC Everio GZ-MG130 Camcorder
Externes Mikrofon - JVC Everio GZ-MG130 Camcorder
How to connect an external monitor when your screen stay whiteMy screen stop working and i don`t see to configure external display!
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 05, 2012 | ASUS M51SN-A1 LAPTOP LCD SCREEN 15.4" WXGA...
Tip
How to connect Laptop to an External Monitor?
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
External monnitor
Plug in the external monitor to the monitor port. Open display properties and set the display to use either 2 monitors (internal and external) pr just to use the external monitor. If just using the external monitor, you can usually us the FN key and one of the function keys to switch to the external monitor.
Aug 21, 2012 | Toshiba Computers & Internet
Mikrofon not working
check weather the the drivers are installed properly
to check right click on my computer icon then goto manage then click on device manager
2>or check weather the microphone is working properly or not by connecting to another computer or laptop
Jul 09, 2012 | Packard Bell E2310 PC Notebook
My mikrofon not work
Hi
Please follow this step
go to "start" > control panel> sounds and audio devices> advanced> options tab> properties "check" recording "check" microphone click "ok"
... "check" select microphone
Make sure that the microphone is not on MUTE mode.
Goodluck
Jun 13, 2011 | Toshiba Satellite A45-S150 Notebook
How to connect external monitor in ibm type 2658
Most laptops have a blue external 15pin video connector. Connect an external monitor's video cable to this port, then power up the external monitor first then boot up the ThinkPad, the video information will automatically divert to the external monitor first.
You can toggle/cycle the laptop and external monitor so they display on both the laptop and external monitor or the laptop LCD screen or external monitor by pressing the blue Fn key and then the F7 key several times.
Jun 19, 2010 | IBM ThinkPad R32 2658 Notebook
1112 cebim var,pilini
Selam
belki telefonunuzu azaltilabilmektedir telefonunuz aç?k ve telefonunuzun ?arj pin temiz .. o arayüzü, mikrofon kulakl?k ve ?arj pin ba?lant?l? oldu?unu ... iyi handsfree telefon hala fixya güvendi?in için te?ekkür .. azaltilabilmektedir olup olmad???n? test etmek için kullan?n ....
Jun 18, 2010 | Nokia 1112 Cellular Phone
Mikrofon model K800i
Its hardware problem bro. Loop mic with a 12k capacitor on the pstve contact and the ground on thi -contact and it will function as good as new.
May 17, 2010 | Sony Ericsson K800i Cellular Phone
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
JVC Everio GZ-MG130 Camcorder Logo
15 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
