Question about Garmin GPSMAP 192C GPS Receiver
Machine won't turn on
Screen flickers then goes blank machine bench tested... works well in West Marine Store power to buss bar and power cable good plug attachment to back of machine good tried turning up light
5 Suggested Answers
  • 6487 Answers
SOURCE: I have a Garmin GPS
If you can try first changing the battery of the unit to check if everything will be working fine, because there's a possibility that the battery went bad or worse the unit has some problem with it , if after changing the battery still have the same problem better have it replace and take the new unit Off Shore for your own good.
Hope that helps..........
Posted on Aug 12, 2008
  • 2130 Answers
Have you tried resetting the unit? The procedure can be located here:
- Jim
Posted on Jan 15, 2010
  • 1417 Answers
SOURCE: When I turn on the
What you need to do is to upgrade the gps device is to reset the system
The Garmin 255W is a GPS navigation unit that helps you determine your location and navigate to a destination by using data from the global positioning satellite network combined with onboard maps. It has a touch screen display. Type in the name of a place to find it on the map, and you will hear step-by-step instructions to get to the location. If the Garmin 255W is having a problem or if you want to erase the data recorded for recent trips or for the vehicle's fuel economy, you can easily reset it by following a few steps.
  1. Touch "Menu."
  2. Touch "View Map."
  3. Touch the "Speed" field on the display.
  4. Touch "Reset Trip." This resets the information in the trip computer.
  5. Touch "Tools," and then touch "ecoRoute." This is where you can enter information about your vehicle's average city and highway fuel economy and fuel type. If you want to reset the vehicle profile data, touch "Reset."
  6. Slide the "Power" key to the left position and hold it for eight seconds to reset the Garmin 225 if it is having a problem.
Good luck and thanks for using fixya.
Posted on Jan 06, 2011
  • 3018 Answers
  • Thing with these Garmin batteries is they go bad after sitting for a while without being used. I recommend plugging it in for 2 hours and then try turning it on and if it turns on it is the battery. Mine did the same thing. It won't hold a charge on it's own but for 20 minutes or so but works fine if I leave it plugged into the car. The reason I say to leave it plugged in for 2 hours before trying to turn it on is because the battery is so dead it will take a while to even get enough of a charge to turn on at all.
Regards, Tony
Posted on May 26, 2011
My garmin 545s does not turn on
My Garmin 545s would not power up. I took the unit to West Marine, where they had the correct cable to hook it up and test it. The unit immediately powered up and I purchased a $22 cable and installed it. Easiest test and fix I could come up with. Really cheap fix.
Sep 25, 2013 | Garmin GPSMAP 545s GPS Receiver
Sylvania 780 with windows 7 powers on but won't display
My sylvania cl772B turns on and shuts right off. what can I do?
Nov 10, 2012 | Sylvania CL772B 17" Flat Panel LCD Monitor
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
I have a dell e1505 laptop you turn it on it flickers to dell for about a 1/2 second then goes virtually black but if you look real close the screen is can still hear it, i hook it to a exteral...
hi there !
-if you switch the computer on and it boots up and you hear the windows sound, this could be a possible video problem or motherboard problem
-run the diags on the LCD, while the computer is off, press and hold "D" then press power button at the same time, if you see the colors red blue green without any problems then it is a motherboard or video card problem
-another method to run the test is while the computer is off; preess and hold Fn then press power button, let the test run; when you see the question were colour bars displayed, press N, if you see the colors red blue and green without any problem then it is a motherboard problem or video card; otherwise it is an LCD problem
-to toggle display on the external monitor press Fn then F8
cheers !
Oct 20, 2009 | Dell Inspiron E1505 Notebook
What is best way to clean and restore a 50' X 50 amp marine power cord? Should be yellow. Is now black!
West Marine (and many marine stores) carries a shore power cord cleaner that works quite well.
Sep 20, 2009 | Hubbell Shore Power 50' Cable Set #6awg...
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Monitor flickering
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
Computer will seem to start, but
if the screen comes up and goes blank again,
1.Remove and replace your RAM with a known good RAM to test with, if it persist or continue, then your operating system by re-updating it,this will help it to recover from the missing files
Apr 24, 2008 | E-Machines eMachines Desktop PC
Garmin GPSMAP 192C GPS Receiver Logo
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
