Question about Samsung ML 1610 Laser Printer
Online/error light The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do?
  • 3 more comments
  • Anonymous Dec 20, 2007
    Same problem. This happened after i fixed a paper jam.
  • Anonymous Jan 02, 2008
    ml 1610 samsung printer does not work after a paper jam. online/error red light is always turned on no matter how i plug/unplug the printer. toner is in place. but i dont know what's wrong with this.
  • norlusaq_92 Nov 04, 2008
    Al encenderla la impresora la luz se coloca verde y al rato pasa a roja, se le cambia el toner y sigue la luz roja.
  • Anonymous Jan 25, 2009
    inter jam then red light always no matter what i do
  • kwrights Jan 26, 2009
    I have tried all three solutions and the error light remains lit. I cannot see any paper that might be causing the issue.
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
  • 70 Answers
There could be three possible problems.
1. Is there paper in the paper tray? If yes then move to step 2.
2. Did u try the above solution and still have the red light? move to step 3
3. The Toner Cartridge is NOT fixed right. You have to take out the toner cartridge and push it in till it CLICKS. It has to make a distinct clicking sound. Turn on the printer again and voila u r good to go.
Posted on Dec 24, 2007
Had same issue and then tried the following for fun. In my case, the problems started after a jam. - Turn off printer - Press the CANCEL button and hold - Turn on power with CANCEL button help down until the printer lights start to flash. Hold for another 5-10 seconds - Let go of the CANCEL button - Power printer off and on again Worked for me but I'm not sure why. Perhaps the above process resets something. Strange though because you'd think unplugging the printer would have 'cleaned out' any leftover errors from a previous print. Wayne
Posted on Sep 11, 2007
2 Suggested Answers
SOURCE:
SOURCE: ML1610 SAMSUNG PRINTER PROBLEM
Posted on Feb 05, 2009
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Aug 03, 2011 | Samsung ML-2851ND Laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
Online/error showing red light, could it be a toner problem ?
it could well be a toner out problem, put paper in the tray and press the button for a second or two, if the light starts flashing and the printer prints a configuration page then its a certainty, also the config page will tell you if the toner is out
Nov 07, 2009 | Samsung ML 1610 Laser Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Samsung 2010 printer
Mine did the same thing, turned out to be an empty toner cartridge. The one that comes with the printer when you buy it only prints about 50 sheets before it dies.
Mar 13, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 1610 Laser Printer Logo
2,251 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
