Question about Sharp Cv-10mh 10000 Btu Portable Air Conditioner Ac Dehumidifier W/remote
When I turn on with remote three lights come on front panel but air does not come on
How to turn the Timer off on Fujitsu AC Model AR-RAC3E? I have tried several times but failed. The Timer light flashes three times every several minutes. The AC does not work at all. The Operation
remove front cover-pull from bottom and lift up at top reset button is above lights try that first , other checks remote battery, control wires 1-2-3 from condenser to evaporator board.
Jan 20, 2015 | Fujitsu Heating & Cooling
Tip
Harmony remote is not controlling Dish Network device.
Hi. For most Dish Network devices, you will have to ensure that the remote address is set on 1 in order for it to be controlled by the Harmony remote.
To reset your Dish Network device to remote address 1, you can do the following:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button.
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
That should get the device working with your Harmony remote.
Hope it helps.
Sources: http://support.logitech.com
on Mar 10, 2010 | Audio Players & Recorders
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
Dec 11, 2012 | Zenith D60WLCD Television
How do I reset the replace lamp indicator light on my zenith d60wlcd tv ?
Aug 30, 2012 | Zenith D60WLCD Television
I need to reset lamp timer on zenith d60wlcd
Jun 29, 2012 | Zenith D60WLCD Television
My new dish net remote will not work on my 3100 reciever. Any ideas?
Hi. You may want to check the remote address settings.
2. Using the Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
Hope that helps :)
(source: support.logitech.com)
Mar 18, 2010 | DISH Network IR Remote Control
Trying to sync my dish remote to a Harmony remote but it doesn't sync. Have a Dishdvr 522
That should get the device working with your Harmony 700!
Hope it helps :)
Mar 10, 2010 | Logitech Harmony 700 LCD Remote Control
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Sharp Cv-10mh 10000 Btu Portable Air Conditioner Ac Dehumidifier W/remote Logo
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
