Question about Frigidaire Refrigerators
Need manual for model # ffu2065fwo csa frigidaire frost free
4 Suggested Answers
  • 1073 Answers
SOURCE: i have a frigidaire electrolux
you have a sealed system issue ned tech to look at this one
Posted on Apr 16, 2008
  • 7 Answers
SOURCE: My frost free refrigerator has frost even with
your freezer is getting frost because the door is not closing all the way. Make the necessary adjustments to the door so that it gets a good seal and the frost should stop
Posted on Nov 05, 2009
heatman101
  • 43501 Answers
SOURCE: Have Frigidaire upright frost free
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 12, 2010
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
Sep 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How do I defrost my FRC 445GM Refrigerator? I don't have the product manual and wonder if I just unplug it where the melted ice will go.
if its a frost free it should defrost its self. if this is a freezer there is a plug in the bottom and a drain port in the front or side of a chest type uprights have a dished bottom for the water collection. If the frost free wont defrost its self the controller or heat element may be bad and needs to be replaced
Aug 15, 2014 | Frigidaire Refrigerators
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
May frigidaire frost free model LFFU1767DW15 have fan motor
Hello David - Typically most of the recent manufacture freezers have fan motors, however some are enclose to where you are unable to reach or see it. Are you having a specific problem with your freezer?
Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Jan 01, 2012 | Frigidaire Freezers
Ocean Frost Free dial keeps going inro Red/Black & we have no Manual
Hi clarry441,
I would like to clarify if what is the brand, type and model name of your unit?
Thank you for using FixYa.
Jun 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need light part # . You reach me @ logy@comcast.net. Heres the # off the Fiigidare Frost Free FCI - 20 Or Model # 61AC4986. Larry
Go to apdepot.com and enter your make of the refirgerator and your model number and you will get an illistration on your machine that will list all part numbers.
Dec 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Refrigerator Question
If it is a side by side model it is frost free. This model number is frost free.
Jun 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
117 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
