Question about Cross Executive EPS-1501X Shredder
The machine is running very slow - Cross Executive EPS-1501X Shredder
My machine runs very slow. I just received a new foot pedal and it still runs slow. What should I do?
If your machine is one of the older (but goodie!) mechanical machines, it probably needs a thorough oiling and cleaning. The old oil has dried and parts are no longer moving freely. Refrain from running the machine until the issue is addressed or the machine may totally seize and the motor may be damaged.
Wheel on right side that controls the needle up and down is very tight...
Jul 21, 2017 | Sewing Machines
Sears kenmore sewing machine model 148-13100 running slow
Did you open the top of the machine and oil every place where metal rubs against metal? Did you do the same under the machine? Use only GOOD quality sewing machine oil. If the machine is slow to recover (it may take a while for the oil to sink in), you can direct hot air from a handheld hairdryer into the internal mechanics. AVOID trying to run the machine until it moves freely or possibly risk damaging the motor.
Apr 23, 2017 | Kenmore Sewing Machines
White model 1563, Runs very slow .
If the machine turns easlily by hand then the problem is probably the foot control. If it is hard to turn it may need to be lubricated.
May 24, 2010 | White Sewing 1632 Mechanical Sewing...
Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Fax running slow
try unplugging machine. then press and hold "stop/exit" button while plugging in machine. continue holding button for 5 secs, then release. that is a procedure to clear any faxes stuck in memory.
hth,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
E4252 machine running new game warhammer
it is ok but not to the video card or the memory card?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Because lagging/slow that's why....!!!
Sep 20, 2008 | E-Machines eMachines Desktop PC
Pc running slow
If a machine is running slow, there is usually 3 reasons...
1) Remove all spyware using a program
2) Run an anti-virus like AVG Free Anti-Virus to clear any viruses
3) Add some memory to the machine
May 07, 2008 | Computers & Internet
Cross Executive EPS-1501X Shredder Logo
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
