Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
1698 trigger fault
No liquid to the floor, but if I select handtools, water is provided. Trigger seems to stick possibly the cause of the problem
  • 48 Answers
Heater blocked with lime scale. or short valve inside unit handle plunger not reaching valve
Posted on Nov 13, 2007
  • Anonymous Nov 18, 2007
    If this is a new machine try taking of the handle an fit a thin shim to the bottom of the handle plunger not to thick, the handle plunger might not be making full contact with the warter release valve
    If it an older machine take of the flow indicator cap remove the red spinner and clean the little white filter,
    make sure the two spray tips under the machine are clesn,
    If this fails and water comes out of the hose but not the spray tips the problem would lay in the heater being blocked with lime scale,
PS: In a fit of frustrated anger I've removed and destroyed the soap selection switch, use needle nose pliers to adjust the depth of the valve for your desired soap mixture (not an exact science)
Posted on Sep 04, 2007
This might help, I've had this one torn apart....way too many times, never enough water, limited water, water starts and stops. I've just now discovered that the problem is in the soap selection valve. if the internal valve is pushed too far down into it's seat, it blocks the water flow enough to cut off the limited suction that stupid little pump provides. You should see and immediate, extreme jump in water flow. Good luck
SOURCE:
Hoover Spinvac F5915900. Trigger no longer causes a release of soapy water on floor. It doesn't have tension, fairly loose, but still in slots. How do I fix this problem?
The trigger that you pull to release water snaps into plastic pieces inside the handle where it pivots to push on the rod that goes down to push on the regulator that lets the water flow. If the trigger is pulled too hard it can break the plastic it pivots in. If this happens the rod doesn't push hard enough on the regulator to let the water flow. Remove the screw at the top of the handle to remove the handle part holding the trigger to see if this could be causing your problem.
Jan 28, 2017 | Hoover Vacuums
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
Dec 03, 2013 | Rubbermaid Reveal Spray Mop Kit,...
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Trigger on hose attachment not working so water sprays constantly
from your description, the trigger sounds like it is stuck in the release position. this sounds like a very simple repair. The component parts need to be looked at by a service shop
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Pro-heat 12
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Jul 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Trigger not working
Sounds like you need to replace the handle valve pieces, if they are available, if not then you will have to replace the hose asm. Just take the valve off and see if one of the pieces have a piece broken off. Then with your model number, you can see if that piece is available from someone that has Hoover parts.
Jan 07, 2008 | Hoover SteamVac F5914-900 SpinScrub...
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
128 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
