Question about Coffee Makers & Espresso Machines
Jura impressa e10
Da li postoji program za jura aparate i zelim preko kompjutera da vidim problem, inace imam servis kafe masina, unapred hvala
  • 4 Answers
SOURCE: Jura Capresso Impressa S9 water won't pull into the unit
mnbkjnjk
Posted on Jun 16, 2009
  • 60 Answers
SOURCE: jura impressa f9 malfunction 8 i need help whats
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Posted on Jul 09, 2009
  • 60 Answers
SOURCE: error 6 for jura impressa z 5 ?
Error 6 means that the automatic ceramic valve having a problem reaching the right position. This is usually related to the main electronic board and there is a chance that this needs to be changed. There could be a possibility that the multivalve is broken, but if you can hear it turning when you start up the machine, it`s probably ok. Contact your dealer for service, or call Jura hotline for your local servicecenter; +41 062 389 82 33
Posted on Oct 06, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Does anyone know how to take apart Jura Impressa
I hope this Jura F90 dismantling guide may offer some clues for your E-series machine. Before you start remind yourself of the risks. In case of a mess up, below I've listed a firm selling spares in Europe. In the UK it is assumed that it you can afford the BMW of coffee machines, you can afford to fix and service it too. However I haven't tried any of the servicing firms so they, and yours could be really, really helpful and cheap. You will need about 4 different torx; hexagonal and possibly unique screwdriver bits to remove all screws. A plastic pry tool (used for mobile phones) will help where plastic lugs hold on the side and top panel. Empty beans; water store and remove the waste tray. On the Jura F90 use pliers to undo two oval headed screws at the back at the top. You'll be able to remove the top panel after using a pry tool to disconnect two lugs at the front edge. You don't want to dismantle the coffee grinder and its hopper. Retain the hopper's rubber seals or glue them in place before you lose them as I did. Four screws hold the central back panel. Slide out a white key underneath the machine (can't recall how crucial this was). The side panels are removed by using a pry tool to release lugs all down the edge where these panels meet the front. Work slowly to manoeuvre the side panels off. If you simply want to clean the brewing unit externally then just remove the panel on the water side. Find the water inlet just where the water tank sits. A screw here allows you to remove a plastic piece - but take a photo of how it slots in. This gives access to the lower end of the brewing unit. If the plastic piece is still it the way, you can ease off the water pipe from the water inlet and put it aside. A number of different brands are made by one firm and branded. Thus the guts of these machines are similar. The brewing unit in the Jura F90 is almost identical in many machines. The screws and attachment places are different. The water inlet and valve are different. Cleaning the parts you can now see may fix a Malfunction 8 without removing and dismantling the brewing unit. The machine is partly operable in this state - cover the exposed electrical connections and remind yourself of the danger here. Thus you can switch off the power when the brewing unit's white wheel is at the top and then at the bottom. In this way you will get access to places causing any jam. You might just need to clear the inner chamber and path for two plungers with two large O-rings. You can see the water inlet nozzle with its o-ring which can perish and cause coffee or water to go to waste. Silicone grease only where the O-rings slide. Leave the other plastic parts ungreased. As I said you might get away with not disassembling the brewing unit. You can however buy a maintenance kit or a new brewing unit from the shop below. You will want to avoid removing the nylon water pipes - unless they're actually leaking. These pipes are held in place with a wire clip (remove with a flat head screwdriver). Ease the nylon pipe with its brass collar out of its socket. The pipe goes into an O-ring in the pipe's socket - this might fall out. Removing a brewing unit is like removing a car engine. The link at the shop below has a pdf (Anleitung_Jura_E.pdf) There is no need to force anything. On the Jura F90 the brewing unit is removed by undoing two obscure screws from the coffee grinder side. I had difficulty removing these and I wish I had taken time to find the right tool instead of wearing down the screwhead. On the electronic side there's an optosensor (encoder) unit held in place with a steel clip. You might remove this to access one of the two screws. At the bottom of the brewing unit, the water inlet valve is fixed to the machine with a single screw. Next, on the water tank side, you'll see two lines of screws that hold the assembly in place. The middle screws of the screws allow you to separate the unit from the gears. The top two holes don't have screws. Coffee machine spare part supplies are not as common in the UK as they are in mainland Europe. You'll find this web useful because of the pictures: www.kaffeemaschinendoctor.de is a German web shop for machine spares AND there's a pictorial of how to dismantle the Jura F90 as a pdf. Google will almost translate it). Juradoctor.de also carry lots of spares but don't seem to ship to my country.
Posted on May 09, 2010
Zasto ne mogu da udjem na facebook,do skoro sam mogla samo preko sigurne konekcije (SSL) a sada vise ne postoji ni ta mogucnost. mislim da je u pitanju virus,sta da radim? Hvala!
Secured Socket Layer or SSL is only active if the site provides a secured payment or access for you to make purchases online. If Facebook gives you this option then you can use this to make purchases on games that Facebook has. If you do not want to or wish not to then it's your choice to give or not to give. These payments are just for earning game points and cash from the games nothing more. Also if your jurisdiction in your country allows Facebook access then.
Sep 05, 2011 | Computers & Internet
Ne mogu da otvorim eksterni hard disk WD1600. Govori mi da treba da ga formatiram.Prije toga je radio i imam dosta podataka na njemu.
Jos ako se cuje klik-klik onda je hard drive spreman za put na otpad. Pokusaj ovo: Klikni desnim dugmetom na ikonu My Computer-manage-storage-disc management.Svi hd koje imas trebaju biti tu,Ako nema eksternala-ugasi ga/ili iskljuci iz struje-sacekaj minutu-opet ukljuci,Pogledaj status:Ako jos uvijek zahtijeva formatiranje i samo formatiranje-onda je crko.Jos jedna stvar: Na ovoj stranici glavni jezik je Engleski. Da nisam slucajno naletio da vidim sta se desava,jos bi ti cekao.Sretno i javi sta se desava!
Mar 01, 2011 | Computers & Internet
Instalirao sam win 7,muzicka kartica ne radi kako treba,kada je pustim na test,cuju se svi zvucnici odlicno (5+1),kada pustim film,crtani,muziku preko bilo kog programa (plejera) cuju se samo 2...
ako ste dr?ali xp sistem pokrenuti u njemu zvu?i kao da win 7 nije uskla?en sa zvu?ne kartice. Win 7 a?uriranje drajvera za tu specifi?nu karticu preuzetu? Ja ne govorim bosinan tako da prelazim na google. Koja je souind karta? google model za nadogradnju 7 ako ve? niste. Nadam se da ?e to malo pomo?i.
Jan 07, 2018 | Genius Soundmaker Value 5.1
Kada na testu,probam zvucnike sa zvucnom karticom genius 5+1,rade svi extra,kada pustim bilo koji film,miziku,bilo sta preko bilo kog programa odnosno plejera cuju se samo 2 zvucnika,inace to se desava od...
Nisu prolem drajveri nego drajveri za zvucna karticu. Najlakse resenje je da kliknes desni na my computer pa manage pa device manager pa sound. vidfeo.... desni na driver za audio i odaberes update naravano moras imati internet. Pozdrav
Mar 01, 2011 | Genius Soundmaker Value 5.1
IMAM DIGITALNI FOTOAPARAT ZNAMKE PRAKTICA,IN KO GA PRIZGEM MI PISE lens error 1114 IN NATO SE APARAT UGASNE IN NE POVLECE NAZAJOBJEKTIVA
Type text or a website address or translate a document. Cancel Listen English to Slovenian translation Pozdravljeni
Problem je, da je objektiv zagozdi v sod. Obstaja nekaj DIY rešitve, ki jih lahko poskusite, vendar pa je verjetnost, da boste morali dobiti jo dolo?i strokovni.
Uporabljajte jih na lastno odgovornost, saj lahko nadaljnjo škodo kamero.
Najprej poskusite priklju?ite adapter za izmeni?ni tok ali usb kabel.
Poskusite gospodarstvo spro?ilec, medtem ko preklapljanje na kameri.
Poglej objektiv, in ?e je nekaj na objektivu krogov "poravnan ali ne koncentri?ni poskušajte wiggling (dr?ite objektiv navzdol).
Poskusite ne?no potiska ali vle?e objektiv, ko se razteza vendar je to tvegano, ker lahko povzro?i cevi objektiva za zdrsnil iz njenih usmeritev sistema.
Drug na?in za to je, da se objektiv navzdol na trdo površino in jo nato mo? gor. Bodite prepri?ani, da uporabite mehko krpo ali kaj podobnega, kot da ni ni? svoj objektiv in ohišje. Naj objektiv push kamero gor in dol nekaj ?asa in v?asih malo odpora, ki ga je kamera dovolj, da stvari gredo spet.
Poskusite hitting vaš fotoaparat v bli?ini le? na telo z mehko tkivo na dlani.
Razen to, jaz bi fotoaparat na popravilo center za oceno, da vidim, ?e bi stalo ve? za popravilo kot zamenjati fotoaparat.
?e je še vedno pod garancijo, jaz bi jo vzamete, preden poskušate koli od teh korakov in odstranite vse off-brand baterije ali dodatki, kot so nekatere trgovine so res sitna o garancijska popravila na kamero z dodatki, ki niso znamke.
Prav tako lahko imajo pogled na link TO.
Upam, da je koristno svetuje. prosimo, ne oklevajte in mi sporo?ite, ?e potrebujete nadaljnjo pomo?. Prav tako, bodite tako prijazni, da mi sporo?ite, ?e ste našli to koristno.
S spoštovanjem
Andrea
Nov 21, 2010 | Cameras
Cao Bogdane
never put email here ,ever, or get SPAM endless for 100 years. wow.
this is an English forum.,
here I used google translate for you
quoted and commented:
"I have one problem.
Namely, I need to perform an experiment with temperature measurement using thermopar. ?????????
I plugged the heaters into the HP 3497 acquisition cortex.
I connect this HP via IEEE488 connections to PC via ISA card (iee 488 card).
WE DONT USE ISA card today, in USA> and software for this is hard to find in year 2017,
The problem is that I can not intimidate that card to work under XP.
WE DONT USE XP today in USA it's a VIRUS MAGNET>!
Do you have any solution?
And do you know a program by which I can read these measurements? I wrote some programs in qbasic.
I installed Labview, but it seems to me that it's quite complex.
I need some simple program, possibly with visualization.
ITS NOT SIMPLE at all to make 488 work.
Thanks in advance
My guess, is you are trying to use HP-IB (IEEE488) communications, cables ( a parallel 2 way comms)
to some ?instruments.? (ask the instrument maker yet)
My guess they are long ago no longer in business or the products are long long gone now.
why not tell the full information on this instrument./?????
makers name, and model #
that takes working software on the PC side.
(drivers for the ISA, and APPS to run it)
the Maker of the instrument would have APP software to run that.
ask them?
if not, you get to write your own software,
and would need the IEEE488 comms library to do that ,and buy it.
you';d also need the book in the instrument in order to learn
the IEEE488, command sets , and address and data forumats.
or its impossible.
Apr 06, 2017 | Compaq Computers & Internet
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
