Question about Dryers
DRYER ON THE BACK OF MY DRYER THE FELT CAME OUT AND A LONG PIECE OF METAL IS HANGING OUT. THE METAL LOOKS LIKE A LONG STRIP OF RIBBON. WHAT DO I DO TO FIX THIS? KENMORE EVENHEAT MODEL # 11062994100
  • 291 Answers
There is a seal on the back of the drum.. that gets hard in spots sometimes... dont know of any metal that could come out.. have u got it apart yet? need more on what it looks like..wondering if this is the seal ur talking about Theres a kit for the drum seal but puzzled about this metal your talking about here is a diagram that may help ya hope the link works http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=0582&modelDesc=DRYER&modelNumber=11062994100&documentID=P0103255&documentTypeID=PLDM&documentClassCode=PM&titleType=BULKHEAD&titleID=00003&
Posted on Sep 02, 2007
  • Mike Johnson
    Mike Johnson Sep 02, 2007
    It works see if you can find it on there and give a # for it
SOURCE:
Aeg lavatherm 33600
just remove the door front panel....the replacement felt is self sticking..........fix the felt with the join at the top...........
cheers
Jul 30, 2017 | Frigidaire GLEQ2152ES Electric Dryer
Dryer making a loud noise
the problem is either going to be the drum bearing or the front upper and lower felt and glides.I'll list a walk-through for you if your interested .
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front piece you just removed.The drum actually rest on these and if damaged will produce a metal on metal dragging sound. If these parts are good, continue to step 5)You now have access to the belt and idler pulley, which is good because the belt needs to taken loose .
6) WIth the belt off spin the drum and listen for the sound that has been bothering you, if any sound other than a smooth sound is emitted when turning the drum your rear bearing is out.
7)You can remove the drum by lifting the back end up and pulling it out. Once you have it out the bearing will be exposed and the rest is just swapping out the old bearing and putting it back together.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 01, 2012 | Dryers
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My dryer started making a loud noise - Amana model alg443raw - then I opened the door and the felt seal and a metal piece were inside and wrapped around my clothes. I know what the felt seal is, but what...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsgfgf
Sep 25, 2010 | Amana ALG443RAW Gas Dryer
A piece of felt like material is hanging from the inside (top) front of the dryer. What is this? Can I fix it myself?
The felt is the seal that keeps the clothes from falling inside the dryer. The front of the dryer needs to be removed and the seal replaced (you can glue it back, but this usually means the seal is worn out)
Apr 21, 2010 | GE DBXR463GB Gas Dryer
I Have a stackable unit. The dryer had some piece of metal/wire tear off of it. I think it was/is something that held the felt piece in place. I believe it was attached to the back of the drum. I know I...
Take the dryer apart, first unplug it, see what else is broke? how bad does the belt look, the wheels in back? and the front seal? then
Write down the model number and do a google search for your model Maytag? parts. I like partselect.com or repairclinic. both have diagrams of parts you will see what you all need to order.
Remember once you remove any panel you will be exposed to sharp surfaces.
Please repost if you have more questions.
Dec 30, 2009 | Maytag Washing Machines
A FELT STRIP CAME OUT OF MY DRYER. CAN I STILL USE
you need to reinstall it because that is what the drum glides on and in time you will hear metal on metal grinding
Sep 28, 2009 | Whirlpool LEW0050P Dryer
Replace the felt on a ge dryer part #we9m30?
You need to buy new felt. There is an upper and a lower piece. The upper piece has 3 glides to support the drum. When you buy the parts, make sure you have the dryer part number and there are some pictures that will help.
Make sure you uplug the dryer. Flip up the top lid of the dryer by sliding a large flat nose screw driver under the front corners of the top. Remove the front panel by taking out two phillips screws. Also remove the power cable to the front controls so you can completely remove the front panel. Strip off the old felt and clean the surface as good as you can. Glue on the felt (you should get a tube of glue with the new felt). Let is dry a bit before you put everything back together. It is a pretty easy job.
Mar 13, 2009 | GE DBSR453EBWW Electric Dryer
Felt belt hanging above dryer door
it sounds like the front drum seal, this is what the drum runs on and seals the surround for fluff ingress. if it is hanging down then it is damaged and will need replacing which will be a partial machine stripdown.
Jul 09, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
335 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
