Question about Yanmar Diesel Inboard Shop Manual - One, Two & Three Cylinder Engines 1980-2009
Yanmar ysb 12 rpm 3000 big end bolt tension,head bolt tension,tappet settings
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
What is the h/p of this chev crate engine,casting # 10066036,what does the cvp stand for at the end of engine number 1m0216cvp.
350 Cubic inches 4.00" Bore, 3.47" stroke
8.5:1 compression ratio.
250 HP @4300 rpm
350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036
2 piece rear main seal 4 bolt main
Crankshaft- # 3932444
Nodular Iron 1985 and older flywheel bolt pattern.
Powdered Metal Connecting rods- # 10108688
Cast Aluminum Pistons-#12514101
G.M. High Volume Pump Oil Pump- part # 12555284
Hydralic Flat tappet Camshaft- #14088839
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194 Exhaust Duration @.050"- 202
Lobe Seperation-112
This cam Has a mechanical Fuel Pump Lobe.
This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808, casting #33417369, 1.94" Intake valve, 1.50" Exhaust Valve, 76cc Combustion Chamber, 7 Bolt style Exhaust Flange Standard, 85' and prior intake manifold bolt pattern. Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
Notes:
Will not work in 1986 and newer applications!
This engine includes Painted Valve Covers, oil pan and Timing Cover. This engine is drilled for both L.H. and R.H. dipsticks. Plugs Are included to plug the side not used.Two timing pointers are also included, a pointer for a 6" balancer and a pointer for an 8' balancer.Balancer with 2:00 timing mark must be used with this engine in order for mark to line up with the pointer.
For most stock applications with HEI ignition, Base ignition timing should be set to 10 before top dead center (with vacuum advance disconected) Total ignition timing should be around 36 @ 3000 rpm.
Spark plugs that should be used are AC Delco R45TS gapped at .045"
Oil filters used with this engine include PF25 , PF35 , PF1218 , or PF35L. The first oil filter is a 1/2 Quart type, the last three are the 1 quart type.
Generally 10W30 or 10W40 oil is used in this engine.
Does Not Include Balancer , flywheel , intake , Exhaust , Ignition , or fuel parts.
Jun 25, 2014 | Crate Powertrain Factory Surplus Crate...
Yanmar tappet settings
Hi there, many engines these days have hydraulic tappets and do not need adjusting. Check if these are like this. I do not know this engine of yours. Regards,
Dave Bisset
Jun 06, 2014 | Garden
Low oil pressure in a ford sabre 350c marine.
Check oil level in sump. Check for correct viscosity of oil for area and temperature. Have the oil pressure check on a master oil gauge to check oil sender unit. Low oil pressure comes from worn big end/ main bearings---worn hydraulic tappets-- loose head tension and oil leaking from head gasket.
Aug 03, 2013 | Cars & Trucks
Big ends torque settings head torque settings
10 mm bolts
step 1 22 ft lbs.
step 2 60 degrees
step 3 additional 60 degrees
12 mm bolts
step 1 26 ft lbs
step 2 60 degrees
May 26, 2011 | 1998 Hyundai Elantra
Whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
hi big end bearings are two stage, 25nm leave ten mins, then 49nm cylinder head bolts three stages 20nm leave ten mins, 40nm leave ten mins then 60nm check after 5,000miles hope this helps
Apr 07, 2010 | 2000 Renault 181
Torque settings clio 1.5 dci big end shells
whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
Jan 12, 2010 | 2000 Renault 181
Timing on 4.7 help
INSTALLATION
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin (Resetting Secondary Chain Tensioners).
  2. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  3. Install right side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.). NOTE: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  4. Install the left side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  5. Install left side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
  6. Install the right side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
  7. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation (Installing Secondary Timing Chains on Idler Sprocket).
  8. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket (Timing Chain System).
  9. Lubricate idler shaft and bushings with clean engine oil.
  10. Install all chains, crankshaft sprocket, and idler sprocket as an assembly (Installing Idler Gear, Primary and Secondary Timing Chains). After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation. NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
  11. Align left camshaft sprocket “L” dot to plated link on chain.
  12. Align right camshaft sprocket “R” dot to plated link on chain. CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
  13. Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  14. Verify that all plated links are aligned with the marks on all sprockets and the “V8” marks on camshaft sprockets are at the 12 o'clock position (Timing Chain System). CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  15. Install both secondary chain tensioners. Tighten bolts to 28 N·m (250 in. lbs.). NOTE: Left and right secondary chain tensioners are not common.
  16. Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 N·m (25 ft. lbs.).
  17. Remove all locking pins (3) from tensioners. CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  18. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left (Tightening Left Side Camshaft Sprocket Bolt) and right (Tightening Right Side Camshaft Sprocket Bolt). camshaft sprocket bolts to 122 N·m (90 ft. lbs.).
  19. Rotate engine two full revolutions. Verify timing marks are at the follow locations:
  20. Lubricate all three chains with engine oil.
  21. After installing all chains, it is recommended that the idler gear end play be checked (Measuring Idler Gear End Play). The end play must be within 0.10–0.25 mm (0.004–0.010 in.). If not within specification, the idler gear must be replaced.
  22. Install timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT / CHAIN COVER(S) - INSTALLATION) and crankshaft damper (Refer to 9 - ENGINE/ENGINE BLOCK/VIBRATION DAMPER - INSTALLATION).
  23. Install cylinder head covers (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION). NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  24. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 81 N·m (60 ft. lbs.) (Cylinder Head Access Plug Location).
  25. Install the oil fill housing.
  26. Install access plug in left cylinder head (Cylinder Head Access Plug Location).
  27. Install power steering pump (Refer to 19 - STEERING/PUMP - INSTALLATION).
  28. Install radiator fan shroud.
  29. Fill cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
  30. Connect negative cable to battery.
Jul 08, 2009 | 2000 Dodge Durango
Yanmar Diesel Inboard Shop Manual - One, Two & Three Cylinder Engines 1980-2009 Logo
71 people viewed this question
Top Clymer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Clymer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
