Question about Raypak Versa 130,000 Btu Above Ground Natural Gas Heater
Raypak 266A digital display inoperative for over a year, heater works fine. Display or circuit board?
    Top Expert:
  • Raypak Master
  • 5,743 Answers
Display
Posted on Apr 27, 2016
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
  • 139 Answers
SOURCE: I get SNS Error on my Raypak Digital pool heater display . . .
refers to flame sensor in combustion chamber
Posted on Jun 20, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Posted on Nov 07, 2009
StepehnD
  • 78 Answers
SOURCE: service code ROL
This indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Posted on Jun 19, 2010
Raypak pool heater troubleshooting
You have to replace the pc board to fix this. In the mean time hit the up arrow button about 30-40 times to make sure you are setting the temp to the max (104 degrees) the count backwards to your desired temp setting.
Aug 11, 2014 | Raypak 130,000 BTU Propane Gas Pool...
I have a raypak p-r335b that won't start the temp LCD displays flicker
check connections to transformer see inside panel for voltages if wires ok see if transformer is going up and down replace if loose wires tighten up if all ok bad display board
Apr 29, 2014 | Raypak Pool & Spa
How to winterize a raypak pol heater
blow out with air then antifreeze (RV antifreeze red stuff)
Aug 27, 2013 | Raypak 266A Digital Cupro-Nickel Natural...
Nothing happens when I turn it on
if voltage to unit check transformer for voltage if ok bad display if display check safety circuit
Jul 30, 2012 | Raypak 266A Digital ASME Natural Gas IID...
HL1 error water not heating
check gas pressure if ok check manual bypass see if spring is ok if broken or stuck closed that if ok see if unit is turning off check gas pressure to see if running out of gas and turning off then gas line filling up and turning on again
May 21, 2012 | Raypak 266A Digital ASME Natural Gas IID...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Versa 130,000 Btu Above Ground Natural Gas Heater Logo
44 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
