Question about Pyle Car Audio & Video
I need to know what each wire is for inside the harness of my pyle headrest monitor i dont have the harness so i cut into the that have five wires in it. there yellow,orange,brown and red one that have a red and a copper wire
Noggin
  • 944 Answers
SOURCE: XO-2703 WIRING
Try these guys - although they only allow installation by licensed installers, so they may not supply parts. http://xovision.com/contact.htm Wiring harnesses for this type of application will differ considerably from vehicle to vehicle depending on the location of the monitor and player and the route through which cabling has to be threaded, so they are usually constucted in situ. The connectors on these units should be standard, so any auto electric shop should be able to wire it up, but be careful not to void any warranty on the monitors. Hope this helps :)
Posted on Mar 19, 2007
  • 11 Answers
SOURCE: A/V AND Power wiring diagram
hi on what you have just told us go and get the same cables that you were using in the old car coz this wires are the ones ment for the screen i mean right holms,right jack pins for it . good luck .
Posted on May 11, 2007
ahamed100
  • 148 Answers
SOURCE: elecrical hook-up for cooktop
Based on your description...it appears the Viking unit may NOT comply with UL and the NEC....but implies that some local Codes may permit the suggested connection...and it may indeed be permitted - if the unit actually draws straight 240 and does not require a neutral for 120 volts (some cooktops do need the neutral for 120 volt control switches...such as your Jennair). Code now requires that new 120/240 units that require the neutral (your Viking unit states that it does not) be a 4 wire assmebly....and your unit MAY be an exception to this requirement.
Under those conditions...then it more then likely CAN be connected as you (and Viking) suggest - black to black, red to red,green to white...and insure that the junction box is indeed well grounded to the supply bare ground wire - so that the metal flex will serve as a supplemental ground to the cook-top.The only other consideration will then be - IS the exisiting wire size and breaker that used to supply the Jennair correct for the new unit..? And if so - then you should be all set with your suggested hook-up...but without electrical nameplate data for both units for comparison...I have no way to determine that....both companies make several different models with different power supply requirements.
If the electrical data is compatible between the two units...then you should be all set as suggested - without having to rewire the cooktop.
Hope this helps...please follow-up if you need more details or have new information for me concerning this cooktop.
Posted on Mar 03, 2008
  • 216 Answers
SOURCE: flip down monitor
Check with a 12VDC from those drill battery.
Positive to red wire
Negative to black wire
Turn on radio.
atdlee@netzero.com
Posted on Mar 08, 2008
  • 7 Answers
SOURCE: changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
Posted on May 08, 2008
Wiring power radio
get a converter cable, dont cut wires.
Feb 09, 2014 | Pyle PLTS78DUB Car Video Player
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
Install rear backup camera
PYLE, 3.5 MONITOR INSTALLATION INSTRUCTIONS, INSTALLED IN SUV. As others have mentioned ThePyle Instructions are pretty much non-existant. As a formerly ASE Certified mechanic I am posting this to try to help others.THE PYLE KIT: Monitor + Camera Mount + Wiring Harness for hard wiring into vehicle electrical. --- Additional Materials Required to Install: 3ea. coils of automotive 18 ga. wire. One red, one black, and one white. 1/8" non insulated wire but connectors, wire shrink wrap (1/4", 3/16\', 5/16" AND 3/8" best to get assort. pack). Self taping sheet metal screws 1/2" long. Roll of electrical tape, Barbed Butt Connectors (2ea.- see illustration wiring Monitor posted this site). Rubber wire grommet 3/8" outside, 1/8" for wire, 1ea. req. Pull ties. --- Tools Required: Utility Knife, Drill w. phillips bit driver, wire tripper, volt meter, small pry bar. + Misc. ---
Mar 16, 2013 | 2004 Hyundai Santa Fe
I got dual (forj) headrests the sound works on the one that has the dvd in it but not the one that does not, the rca jacks are hooked up to it, it has speakers in it, does it even have sound?
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
Dec 12, 2009 | Dual Car Audio & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Having trouble installing my Pyle PLDBT30U
your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link - http://cgi.ebay.com/FORD-2003-2007-HARNESS-METRA-70-5520_W0QQitemZ170248469364QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20.l1116
i dont think this model has a premium sound upgrade.... could it be a changer cable?
Dec 28, 2008 | Pyle Car Audio & Video
I need a wiring harness or a picture of the wiring harness for a pyle PLTSN74
I NEED TO FIND A WIRE HARNESS FOR A PYLE IN THE DASH DVD PLAYER PLTSN74
JONES-RAY@sbcglobal.net
Jul 21, 2008 | Car Audio & Video
Car Audio & Video Logo
35 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
