Question about NetGear WN2000RPT Repeater
Setup wizard I am having problems setting up my netgear wifi WN20000RPTv2 range extender.
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: I have a Netgear Universal
What is the last thing that happened before you noticed there was a problem?
Posted on Jan 13, 2011
Trying to setup my netgear wifi range extender
If you look on the back of the unit, it should have in small print, the access IP address, the admin name and admin password. If you have changed it in the past, then reset it back to the default. Typically netgear use 192.168.0.1, admin name of admin, and the password is either password or netgear1. Older units may use 1234. The only exceptions are newer extenders that ask you to put in a password when you set it up, in which can you will need to reset it to the defaults and do a new setup.
Jun 16, 2016 | Uniden exi4560 2.4ghz extended range...
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Setup wizard
the password should be the same password of your wifi on the router...
Aug 21, 2013 | NetGear WN2000RPT Repeater
Netgear wn2000 connect to bt home hub 3
got that ! netgear wifi extenders ? go to mywifiext net mywifiext Setup for Netegar Wifi Range Extender as i never had issue with my netgear by once my friend had ! and he came up with this website saying in case if you need help then just simply call them ! but i never had issue so ! hope this will help for you ! and there was a another website too Mywifiext net setup both serve free service ! about netgear wifi extenders and genie setup ' mywifiext
Feb 19, 2012 | NetGear WN2000RPT Repeater
How do I setup the Netgear WN3000RP Range Extender with a MAC
hello Friend
meathod is same eathyer its windows of mac . Just follow the same steps Ib both platforms.
Please Visit How to Setup Netgear Range Extender Mywifiext net And setup your Netgear range extender .
I hope this may help you setup your extender. Thanks
Dec 27, 2011 | NetGear Universal WiFi Range Extender...
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Why can't i connect to mywifiext.net
3 lights on every time last two days one light is on first last we dont on its the problam
Sep 30, 2011 | NetGear WN2000RPT Repeater
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
NetGear WN2000RPT Repeater Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
