Question about Samsung WF8704RSW
The water inlet holes in the dispenser drawer of my wf870rsw keep getting blocked with black sediment. what is the solution please?
Water not draining from my dispensers
Water pressure or blocked inlet valve.
Take out the soap drawers and have a look up at the inlet holes.
Mar 16, 2016 | Washing Machines
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 05, 2009 | Washing Machines
Conditioner not being used from central drawer during cycle. Why and how can I rectify this?
There can be 2 reasons. The centre section dispenses the fabric softener in the last rinse. It works on a syphon effect.
If it is not assembled correctly the water flows over the side to avoid a flood and leaves the middle section full at the end. Make sure the inner pipe is inside the outer pipe and that both are completely clear of softener residue.
The second reason is the water inlet can become blocked therefore not creating sufficient flow to create a syphon effect. It gets blocked with black gunk and needs to be cleaned with pipe cleaners or a long cable tie. There are 4 rectangular holes above the centre section, near the front. They can be seen easily if you take the drawer out.
Hope this helps
Nick
Jul 27, 2009 | Bosch Washing Machines
Fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
Jan 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WFLI2440 FRONT LOAD FABRIC SOFTENER NOT DISPENSING
your soap drawer is most likely to be blocked , the only true way of clearing the blockage is to take the soap dispenser completely out . you will see that all the jets will be blocked ,you can do this before taking it all apart by taking the drawer out band looking up, if it looks clean ie; no black gunge then it may be a water valve problem, as the cold fill side has 2 internal valves both have come on together to clear the conditioner compartment.
Feb 15, 2008 | Bosch WFLI 2440 Front Load Washer
DISPENSER WILL NOT DRAIN
Waag, pull that dispenser drawer out of there, push down on the tab-left side in the back. Now take your index finger and see if you have something blocking the water feed hole to the tub. It will be on the inside front. Sometimes I find bottle cap disks blocking the inlet. Start a cycle with the drawer out of there and observe the water flow, if it's backing up, you have something blocking that inlet. You can always pause/cancel. Catriver.
Jan 01, 2008 | Kenmore 46462 Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Front Loading Washer Does Not Dispense Softener
its not the sediment that is the problem the filter will do nothing for this problem.The best thing to do is to remove the drawer from the machine and clean the syphon on the softener compartment.It becomes blocked when excessive amounts of wash powder is being used.Alternatively the powder can be put straight into the drum.
Mar 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF8704RSW Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
