Question about Bosch Nexxt 300 Series WFMC2201UC
WFMC2201UC/16 BOSCH NEXXT SERIES 300. The plastic look through bubble on the front door leaks around the grey plastic seal. I just need that part/part # I do not have the owners manual. email me kidhauler03@yahoo.com PLEZZZ
barkencoa
  • 3463 Answers
SOURCE: How do you replace the
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
  • 130 Answers
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
  • 1525 Answers
SOURCE: the door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Posted on Mar 27, 2009
  • 157 Answers
SOURCE: HELLO I have a Bosch Nexxt 300 series and I
under loaded fill it up
Posted on Jun 30, 2009
  • 23 Answers
SOURCE: putting on spring loaded wire seal ring on a bosch washer
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.
how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
Posted on Aug 13, 2009
Seal has holes
e13 is excessive drain time, normally down to blockages in the pump filter. this is at the front right hand side normally behind a flap and should unscrew counter clockwise.
Apr 10, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Leaking water
If it is still under warranty, I would call customer service. If not, I would call the place you bought it, and explain the issue. I am sure they can order the part or give you somewhere to order it. Is it a removable seal? If so, you should be able to six it pretty easily yourself. here is the manual. Hope this helps.
http://www.ajmadison.com/ajmadison/itemdocs/9000224447_ver03_WFMC2201UC.pdf
Jul 31, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 series WFMC2201UC has no water coming in. I have replaced the inlet valves, cleared all screens in hoses and still no water. It seems there is no power to the inlet valves. Is there a...
You can check the inlet valves with either an o'scope or a multimeter. Unfortunately, the control module PN: 661081 controls the voltage to the inlet valves and costs around $240.
Sorry, to give you the bad news.
Jun 09, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Leaking
This video will show you how to replace the Bosch Next 300 Series WFMC2201UC washing machine door seal with step by step guide on the process of how to fit and replace
Apr 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Our Bosch Nexxt 300 washer has a small piece missing from the door seal gasket - I'm a skilled home remodeling contractor - Should I attempt this repair - Are instructions an diagrams available - Who...
Bosch Nexxt 300 washing machine
door seal on this Bosch front loader washing machine and where to get the parts!
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Putting on spring loaded wire seal ring on a bosch washer
Jun 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
