I just bought a 2003 GMC Sierra SLE 2500 Crew Cab Duramax. it has 55 Thousand miles on it. The Electric Mirrors do not work (Drivers & Passengers) I have checked all the fuses. Under Hood & in Cab. I have pulled the Door Control Module off (Driverside) There is Power to the Orange wire to the Module. All the power windows work. There seems to be 2 printed curcuit boards in the DCM. Just no Mirrors. I have dug Hi & Low and can't get a Wiring Diagram for it. Is there test I can do to determin if the board is faulty. If I buy one I am sure it is non-returnable. Any ideas are welcomed! Cheers!
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
SOURCE: HAVE A 03 GMC SIERRA
I had the same problem in my wife's 2003 Yukon Denali. The power seats and passengers side window wouldn't work. Turned out to be a blown Buss Type fuse in the Underhood Fuse Block. It is the one marked MBEC 1 50amp. Hard to tell if the are blown so look very carefully. Should look like a hoop with two shiny solderlooking bubbles on either side. On my blown fuse, it caught my attention because it looked like the solder was missing and I had to look very closely to see the bottom of the "hoop" was open. They are very hard to remove and must be pulled straight up.
This type of fuse looks like a red square with a clear plastic top showing the fuse link under the plastic. On my vehicle it is on the top row second one from the left.
SOURCE: Power Door Lock Problem
The last post by maddog1321 was exactly what I had with my right rear door. The electric locks would not lock and unlock, and you almost couldn't do it manually without my feeling I was about to break something. I took the door panel off, oiled everything and got no relief. Finally, I saw the above post and drilled out the aft-most pop-rivet. THE WINDOW WORKED PERFECTLY! I didn't drill out the forward (closest to the handle) pop-rivet because I wanted to do one at a time so the solenoid would not fall out of place. I then put a new pop-rivet in place of the one I drilled out. I then reinstalled everything and the locks work like new.
SOURCE: stereo wiring diagram
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: 2000 GMC Sierra Power mirrors do not work
sounds like a switch as common error oboth sides unlikely
Testimonial: "Thanks, I'll give it a try"
SOURCE: wiring diagram 2003 GmC Sierra
I need wiring digram for GMC 2003 SIERRA . I have the left head light working fine but the right I have no power to it. I have checked the fuses and relaysand so far have not found and broken or frayed wires.
2002 Chev 2500HD exactly same problem. Anyone with diagram???
