Question about Hampton Bay Televison & Video
How do I replace the glass globe - Hampton Bay Televison & Video
I am unable to remove the glass globe on the fan to replace a burned-out light. Do you turn to right or left to remove. Is there a trick to it?
is this a ceiling fan perhaps if so there are 4 little screws that hold gloobe up try lifting the globe some while you loosen screws
Mar 08, 2015 | Dryers
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
Replacing oven light
In general you slide out the front glass cover on the light, which generally just sits in metal slots or clips. Then remove the globe, which commonly is an ES type so you screw it out anti-clockwise.
There are 2-3 sizes of oven globe so take the old one along to the hardware store for a match. Don't buy a standard globe, it will fail, oven globes are tougher.
Nov 27, 2013 | Ovens
We purchased a Hampton Bay Southwind V Celing Fan from Home Depot and the glass globe over the light bulb was cracked. Where can we get a replacement? We can't find the information that was in the box.
You can find a replacement at Walmart, Lowes, or Home Depot.
Go to any of the above websites and run a search by entering "light kit replacement glass", or just plain "globe". It should cost between $ 3.50 - $10
good luck
Mar 24, 2011 | Computers & Internet
I need a new globe for my Hunter fan 28505 I think...
You can locate parts at hunterfan.com or call for parts at (901) 248-3237 This is the
technical service number given to me by the hunter rep a few years ago.
If you need a generic globe, they are available at home depot and lowes in the
replacement glass section "Angelo Glass"
All you need to do is measure the diameter of the
"fitter". This is the metal part the glass fits into and holds it, usually with 3 thumbscrews.
Mar 03, 2011 | Hunter Heating & Cooling
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
How do you change light globe in simpson evolution 904 oven
The glass cover definitely unscrews anti-clockwise, but mine was impossible to start moving by hand. I used a pair of adjustable pliers and while the glass cover is made out of pretty thick glass, I didn't want to be squeezing it so I set the pliers jaws to exactly the same width as the glass cover. Because the glass cover has 4 bumps set around it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're looking for a replacement, keep in mind that it has to be a max of 25W.
Oct 26, 2010 | Ovens
I am looking for a replacement glass globe for my laurel woods westinghouse ceiling fan. Can you tell me where I MIGHT FIND ONE
Lowes and Home Depot each have many glass replacement globes that will fit most any ceiling fan light assembly.
You will need to know the diameter of the glass where it goes into the metal part of the light and the depth that the globe needs to be to clear the lgiht bulb.
Heatman101
Feb 26, 2010 | Dryers
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Dyna-glo glass globe
go to this site they have mica windows and accessories for your heater:
http://www.milesstair.com/accessories.html
Nov 27, 2007 | Heating & Cooling
Open Questions:
Televison & Video Logo
42 people viewed this question
Top Hampton Bay Televison & Video Experts
Tom Chichester
Michelle Balcom
Are you a Hampton Bay Televison and Video Expert? Answer questions, earn points and help others
