Question about Sharp CV-P09LX Portable Air Conditioner
Water coming out from the bottom while it's on. The two drain valves are closed and the water has been drained.
Vulcan electric hot water heater. I want to know how to drain enough water out in order to replace the relief valve
turn off unit turn off water supply open drain at bottom let water out close drain remove valve
Aug 31, 2017 | Water Water Heaters
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Heater comes on with water
please see the next step:
he pilot light may be out or may not stay lit. There may not be enough hot water, or the water may be too hot. The water heater may leak or be noisy, or the hot water may be dirty.
A problem with your water heater may be due to overwork, not mechanics. If your water heater holds less than 15 gallons per family member (tank volume is stamped on a metal plate affixed to most water heaters), consider a larger unit or staggering your use of hot water.
Drain a hot water tank:
  1. Turn the gas-control knob to off and close the gas-shutoff valve.
  2. Close the cold-water supply valve and open a hot-water faucet in the house to speed draining.
  3. Attach a garden hose to the drain valve and run it outside to a drain. If the heater is in the basement you may need to run the hose to or through a sump pump.
  4. Open the drain valve and allow the tank to drain.
  5. Once done, close the drain valve, open the cold-water supply valve, and open any nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full; close the hot-water faucet.
  6. Once the tank is full, turn on the gas and relight the pilot.
Jul 31, 2012 | Heating & Cooling
I am getting a message ''Water in Diesel Fuel Filter'' on the computer display of my Peugeot 206 Diesel SW Quiksilver. It was recently serviced. I spoke to the guys who did the service, but they want to...
its pretty simple, locate the fuel filter housing, at the bottom of the housing is a valve, just open the valve for about 3secounds to allow water to drain some fuel will also drain out, close valve and start engine and allow to run for a couple of minutes,
Apr 12, 2010 | 2005 Peugeot 405
I am trying to drain my electric water heater: Servistar, model no.06443 serial no.0496B02329, watt: 1-PH,Upper 4500 240 volts only, Lower 4500 Cap. U.S. Gallons 50 Total 4500 I closed the cold water...
Hi Karen, think of the water heater as a straw....if the straw has liquid in it and you put your finger on the top, the liquid doesn't come out. If you open up the relief valve, air will allow it to flow freely. The relief valve has a metal lever on it, usually on the top of the water heater (if electric).
Feb 06, 2010 | RTO Home Heating Products 5.5HH240...
Where you connected the hose there should be a round handle,make sure that it is open. If water still
does not drain out, it is possible that it is limed up.
Get a bunch of bedsheets ready! Make sure water heater has cooled down, open the drain valve, if no water comes out then stck a long screwdriver and try
to poke it inthrough the valve. Be ready alot of water
or a little water should come out be ready to stick
garden hose back on. This should start draining
Feb 06, 2010 | Heating & Cooling
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
Water in bottom
This sounds like your backup valve is not closing properly, so the part of drainage water comes back into your dishwasher. You can verify this by disconnecting the drain hose from your kitchen sink drain and pouring water into it. If some of it comes into your dishwasher, the check valve (backup valve) must be replaced.
Dec 16, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 21, 2008 | Washing Machines
Sharp CV-P09LX Portable Air Conditioner Logo
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
