Question about Hailo 0850-869 Large Volume Bin / Kickmaxx 50 / Capacity 50 Litre / Stainless Steel Push Flap / Bin And Lid Made Of Sheet Steel Vanilla / The Internal Bin Is Galvanized
Pedal broken on bailout kick max 50 - Hailo 0850-869 Large Volume Bin / Kickmaxx 50 / Capacity 50 Litre / Stainless Steel Push Flap / Bin And Lid Made Of Sheet Steel Vanilla / The Internal Bin Is Galvanized
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
How to adjust 95 geo tracker clutch
engaging?
you meant dis-engage im sure.
pedal up is engaged,
pedal at floor dis-engages it.
my guess, is the clutch drags unless i push the clutch pedal 100%
to the floor.
1: bad cable is 90% cause. non last this long.
2: no free play is way too loose.
3: broken lever on the pedal top. caused by #1
all fail modes covered here.
http://www.fixkick.com/tranny/clutch/clutch-on-kick.html
Apr 23, 2014 | Geo Tracker Cars & Trucks
2000 Ford Focus. Transmission won't upshift unless I let up on the gas pedal. It will shift if I'm accelerating easy, but under a heavier load it won't. - Catalytic Converter isn't blocked...
it sound like it could be a vacuum problem. I have experienced this on cars i have worked on it usually turns out to be a vacuum problem 90 percent of the time.
Jul 14, 2011 | Ford Focus Cars & Trucks
My Boss RC-2 Pedal is having a problem with the output. With the volume turned up to max, the signal is suddenly extremely faint on can only be heard if there is silence in the room. Even the backing track...
Most PROBABLE is the output jack either has been broken (common due to mishandling and accidents with cables such as stepping on the plug while plugged into the pedal) or the soldering of the jack in the pedal has broken loose. Less common is a circuit board crack in the vicinity of the jack. Open pedal and inspect for the above suggestions.
Mar 11, 2011 | Roland Boss RC-2 Loop Station Stompbox...
How do I release my 1995 Gmc sierra parking brake if the release cable is broke
if you look in footwell area at kick panel where the ratchet pedal you push down to apply brake you will see where it was attached [cable/or rod] take a pair of needle nose pliers and move lever it was attached to be careful don,t let pedal fly up and smack you when it releases if this does,nt work or need more info contact me @ fixya will reply asap
Mar 19, 2010 | 1995 Chevrolet S-10 CA Edition
Kick pedal for rock band dosent work
kickpedal is probably broken or not setup right now do this: do NOT take it apart ever! it will break right away ill garantee it and last dont mess around with it or youll make it worse do this plug the headphone jack thinkg to the drumset and try that and if it doesnt work then play w/out pedal you can still play w/out it
Dec 31, 2008 | MTV Games Rock Band for PlayStation 2
I acutually snapped my rock band kick pedal in half and discovered alot about it. The way the kick pedal actually works is with a little magnet thats under the orange part. if your orange bar piece fell of or anything check that or take a magnet and tap the top of the kick pedal near were the wire comes out and if it reacts on the game then theres nothing wrong with the kick pedal just check the little magnet make sure its there. After I broke my kick pedal i went out and cut a piece of diamond plate metal in the shape of a foot and basically made another pedal piece and welded bigger magnet on it and now it reacts on time and alot better it seems cause its heavier. Hope this helps!!
Dec 30, 2008 | MTV Games Rock Band for PlayStation 2
Yahoo not opening
Yahoo must be having problems with their servers that serve those webpages. There is nothing you can do as a user to make those webpages work.
Nov 26, 2008 | Yahoo Mail
2005 camry tail light blows
Does it work when you press the brake pedal? If so, sounds like you have a faulty bulbs. IF it doesn't work when brake pedal is applied I would check the fuse under the hood or left kick panel on the driver side.
Sep 20, 2008 | 2004 Toyota Camry
Hailo 0850-869 Large Volume Bin / Kickmaxx 50 / Capacity 50 Litre / Stainless Steel Push Flap / Bin And Lid Made Of Sheet Steel Vanilla / The Internal Bin Is Galvanized Logo
102 people viewed this question
Top Hailo Home Experts
john h
Tom Chichester
Are you a Hailo Home Expert? Answer questions, earn points and help others
