Question about Maytag Microwave Ovens
Maytag microwave model umc5200bas is not heating
localwonder
  • 6784 Answers
SOURCE: Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 10, 2009
  • 670 Answers
SOURCE: Microwave no longer heats, makes more noise than
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
Testimonial: "Thanks, I talked to the manufacturer and they suggested the same. Thanks for taking the time to reply."
heatman101
  • 43501 Answers
SOURCE: microwave maytag
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
heatman101
  • 43501 Answers
SOURCE: is there a reset button
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Posted on Apr 22, 2011
  • 1606 Answers
SOURCE: I have a Maytag UMC5200BAS
Most likely the magnetron power / fan / cavity lamp relay is stuck on. Sometimes the contacts on mechanical relays get welded together. Some ovens use a triac (solid state AC switch) for the magnetron; this may be shorted. The part probably costs no more than $7 from an electronics supply house such as Mouser or Digi-Key, but you'll want it replaced by someone who is good at repairing printed circuit boards.
Unplugging the oven was an excellent idea.
Posted on Jul 29, 2011
How do i replace the light bulb in a maytag UMC5200BAS wall mount?
The only way is too remove the cover to the microwave. Part number WP4713-001012. If you have never entered into a microwave you may want someone to do this for you. Safety first!!
Good Luck
Jun 28, 2014 | Jenn-Air Microwave Ovens
I have sparkin and arching in the magetron cavity
remove cover inside microwave oven and clean the cover and the metal around it if it still arks replace the megnatron
Dec 06, 2013 | Maytag UMC5200BA Microwave Oven
Is there a reset button or fuse in a wirlpool umc5200bas microwave?
heatman101
Apr 12, 2011 | Microwave Ovens
My oven makes a humming noise when it is running - either in heat mode or defrost mode. The noise goes from nothing to loud, then loud, then it quits. The microwave is only 2 months old and it has been...
No! this not normal and should be checked out right away, the problem could be in the high voltage transformer being loaded down by the magnetron, or possibly the turn table motor. The warranty must still be in place and I encourage you to take at vantage of it.
Jan 14, 2011 | Maytag UMC5200BA Microwave Oven
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
Inside white porcelain paint has defects
It should be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
It's normally enamel on sheet metal, not porcelain.
Jan 16, 2009 | Jenn-Air JMV8186AA Microwave Oven
Shaft from Jenn-Air microwave - part (58001050) unavailable -
Check with www.microwaveglasstrays.com or call them toll free 1-877-894-0035
Parts should not be a problem to find - just need to clarify what part you need.
Dec 12, 2008 | Maytag UMC5200BA Microwave Oven
Turntable shaft
In case some local appliance shops or appliance parts stores may have one setting duty on the shelf, the part number was 58001050.
Do you still have the old part? Can you post a photo of it?
J.B. Weld brand epoxy might fix it, if applied sparingly... you may have to get creative...
You can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart recently). It's shown below.
If you find one, you can plug the shaft hole with a rubber plug from the hardware store and use this.
Aug 28, 2008 | Maytag UMC5200BA Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
