Over load ligth does not turn off now i have no sound
    Top Expert:
  • Audio Player... Master
  • 34,153 Answers
The overload light will stay on until you find what caused it to turn on the first time. This will require opening up your unit and troubleshooting the circuitry
Posted on Aug 01, 2013
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
Replace ligth swicth dimmer swicth brakes and singal litghs work no head ligths
Sounds like your turn signal switch is bad!! Multi-functioning switch it controls your head lights two? Unless you have a push button switch!
Sep 04, 2011 | Chevrolet Chevy Cars & Trucks
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
My brake ligths and blinkers does not turn on. why? but, if i turn on my ligths , yes the rear ligths they are on just the brake and blinkers not
Defective Hazard Switch or Turn Signal Switch will most generally cause this problem on GM vehicles!
Mar 08, 2010 | 1999 GMC Yukon
The brigth of the rigth head ligth is dimished
you mat have a shorted bulb try changing the bulb if that doesnt work you probably have a bad ground
Feb 06, 2010 | 2003 Suzuki Grand Vitara
Hi,my suzuki m-50, '07 right rear signal ligth isnot working
it sound to be corroded connections onn rear light cluster remove clean and replace
Oct 06, 2009 | Suzuki Boulevard M50 Motorcycles
No turn ligth and no stops ligt
gmc had a recall for that problem. It is the switch under the break pedel was installed wrong during manufacturing. Took mine in and they replaced switch.
Aug 09, 2009 | 1994 GMC Sierra
I have a 93 g20 chevy in a very good shape, last week starts to make a sound (trrr)and turns on the abs ligth, I turns the switch off and on again and it fix the ligth off. could be the abs module, or a...
That sounds like the ABS pump. If you have 4 wheel ABS that pump has a history of problems Leave it alone if its working now. Pump is very expensive.
Mar 01, 2009 | 1993 Chevrolet G20
I don´t see the ligth of the car in the nigth
Have hadlights aimed. Sounds like they are aimed too low. This happens as the sprnigs sag in the front more that in the back due to the increased load on the front.
Aug 09, 2008 | 1988 Toyota Tercel 2 Door
37 people viewed this question
 Grubhead
Grubhead
