Question about Polaroid Patriot 8GB Sdhc High Speed Class 6 Memory Card for Canon Eos Rebel T1i EF-S DSLR Digital Camera - Secure Digital High Capacity 8 G Gig GB 8gig 8g SD HC Free Card Reader
How to solve F:\RECYCLED\e2a38afd.exe.? - Polaroid Patriot 8GB Sdhc High Speed Class 6 Memory Card for Canon Eos Rebel T1i EF-S DSLR Digital Camera - Secure Digital High Capacity 8 G Gig GB 8gig 8g SD HC Free Card Reader
Error 10.1000 supply error
The HP LaserJet toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. We have devised a work around to fool the printer into not displaying the message.
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
Post back if it is not working we will be happy to help you.
Thank you.
cheers!!
Jan 07, 2011 | Computers & Internet
10.1000 Supply Memory error. How can I fix that?
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
Jun 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
Orange light flashing when i installed the printer
solved the problem by changing the cartridges. recycled cartridges do not work with this model
Nov 30, 2009 | HP DeskJet 5150 InkJet Printer
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
Used recycled ink and stopped printing.
In view of the lack of interest by kgnmadi in this problem, we can only assume that it has been solved - "Solved by Poster".
Jan 07, 2009 | Epson Stylus C84 InkJet Printer
Lexmark x4850 ink refill problem
Did you get a genuine Lexmark cartridge or a recycled one? The recycled ones will usually work fine, but the printer may not know how much ink it has. So it will print all right until the ink runs out and the print quality deteriorates. If you used a genuine Lexmark, then I'd suggest you take it back to the store you bought it from and get a new one.
Nov 29, 2008 | Office Equipment & Supplies
Lexar USB drive
Any valid ctfmon.exe file is located in the folder C:\Windows\System32. In other cases, ctfmon.exe is a virus, spyware, trojan or worm! There is no good reason that it should be in the recycled bin. I would suggest first making sure you have a valid file in the location indicated. Then, if that is there, delete the file that is in your Recycle Bin. This file is necessary for running various tasks related to the language bar, and runs in the backround constantly monitoring the windows that are being utilized.
Based on the message you have indicated, it appears that you may have a virus or other malware. Aside from taking the actions above, you should make sure you have scanned and protected your PC from these destructive processes. Then you should not have any further issue. If you do, please let me know. Thanks for rating FixYa!
Apr 29, 2008 | Electronics - Others
Virus
Assuming you have an anti virus and spyware programme installed:- you need to turn off system restore first as it backs itself up and then run your anti virus programme, prefferably in safe mode, restart the pc and turn system restore back on.
Nov 19, 2007 | Microsoft Windows XP Professional for PC
Polaroid Patriot 8GB Sdhc High Speed Class 6 Memory Card for Canon Eos Rebel T1i EF-S DSLR Digital Camera - Secure Digital High Capacity 8 G Gig GB 8gig 8g SD HC Free Card Reader Logo
95 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
