Question about Zenith Televison & Video
Zenith Z50PT320 suddenly loses picture, keeps sound. Yes, I unplugged and replugged it. It is set up correctly and has worked fine the last year. Today, the video just stopped. Thank you!
    Top Expert:
  • Zenith Master
  • 74,136 Answers
Check its back-light inverter section, and back-light CCFL lamps.
Posted on Aug 01, 2013
3 Suggested Answers
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
  • 135 Answers
SOURCE: no picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Posted on Nov 11, 2008
Zenith 50" plasma TV model Z50PT320 has no picture no sound just flicker screen with lot s of fuzzz
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Feb 12, 2017 | Zenith Televison & Video
I have a Zenith Z50PT320 plasma tv. After a few minutes the picture turns very posterized and flickers. Should I replace the Main Logic CNTRL T-Con board?
There is no T'Con board to Plasma TVs. Flickering can be of many reasons. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 09, 2016 | Zenith Televison & Video
I have no sound from Xbox HDMI connection.
you likely connected it with one or both units involved on and HDMI does not like that--prone to all sorts of audio issues.
If in doubt unplug the units and wait and plug back up making the connections first.
Jun 07, 2012 | Zenith " 50"" Class - Plasma - 720p -...
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
Mar 24, 2010 | Zenith R56W36 56" Rear Projection...
Zenith 27" TV
I sorry to say I think you have a component failing that is related to heat. 15 years is a long time and if the TV was used in hpot conditions over the years it may well be the proble, or it's just old.
Sep 23, 2008 | Zenith C27A24T 27" TV
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
TV - no audio
TV wirked fine for years, but when we moved it to a new house 100 miles away the sound was gone even the cable supplied picture is great. Cable company couldn't recover the sound either.
Mar 04, 2008 | Zenith B25A24Z 25" TV
No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Feb 22, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
80 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
