V zon lcddvd3250
Does this model have a QAM tuner?
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
No. It hasn't.
Posted on Aug 01, 2013
2 Suggested Answers
SOURCE: Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Posted on Dec 07, 2009
Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
Feb 23, 2017 | Televison & Video
Does my Emerson LCD TV/DVD combination model LD195EM8 7 have a internal QAM tuner?
The Emerson LD195EM8 7 does not have a QAM tuner. It just has the ATSC (digital OTA) and NTSC (analog OTA and cable) tuners. Emerson TVs are manufactured by Funai. You can find most of their manuals here: http://www.emersonaudiovideo.com/support/download.php . Enter your model number without the 7 to find the download link; the direct link is hidden in the Java script. Sears Parts Direct also has the manual. The direct link to the LD195EM8 manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0810491.pdf .
I wish that I had better news for you. I hope this helps.
Aug 17, 2015 | Emerson Televison & Video
Activate QAM Tuner
QAM tuner fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Westinghouse LD-3235 32in LED 720p Flat...
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    How do i know if my tv has a quam tuner im not
    First it is QAM (quadrature amplitude modulation) and is used only on cable systems. Know that you will only get clear-QAM, this is, those not encrypted. This means only the local channels, which they are not allowed to encrypt. It will switch automatically, so if you get any HD it will be QAM. They will have names like 85-1 for digital source, not necessarily HD. Not all set-top boxes can tune digital channels--check with your cable system. You have called them? Be sure to remind them on your STB make and model, they may need to replace it. -Ken
    Jul 16, 2009 | Samsung Televison & Video
    Polaroid Model TLX01911C
    Greetings!
    This set is listed as having the ATSC (Advanced Television Systems Committee) tuner. This tuner provides reception of digital over-the-air (antenna/rabbit ears) signals and would therefore not need a converter box fir that use.
    If you are trying to receive un-encrypted digital signals from cable, the ATSC tuner does no good. The set would then require a QAM (quadrature amplitude modulation) tuner. I am not sure if this set has a QAM tuner or not. Even if it did not, your cable provider must provide a way for you to receive their signal and should make their converter box available to you.
    Hope this helps explain things a little,
    Rob
    Jan 14, 2009 | Polaroid TTM-2003 Combo
    Ready for nat'l digital transition?
    If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
    May 23, 2008 | Recoton Advent Advent HT3251A TV
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
