Question about Whirlpool 24 in. GU940SCG Built-in Dishwasher
MY LAMONA DISHWASHER WILL NOT START THE LIGHTS ARE ON BUT NOTHING ELSE
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
Howdens dishwasher hja8362
The water in the machine is normal there is nearly always 1/2 a lit to a lit of water when a load is finished. Also if you dishwasher is out of warranty there Re a few things you can do one go buy a $20 voltmeter and unscrew the face plate and see if anything is lose mine hade a wire come lose and made the hole thing misbehave.
Jan 26, 2014 | Dishwashers
Lamona hja8630
How do I remove the integrated door af a lamona hja 8630
Jan 01, 2014 | Dishwashers
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 | Dishwashers
Lamona dishwasher, all lights are on, tried resetting and cleaned filters
Hi.
Make sure that you did a complete reset by disconnecting power at the circuit breaker for about ten minutes. Make sure that the door is closing properly, double check drain well and check that there is no residual water inside the tub when the cycle starts.
If that is not enough the machine must be removed from the cabinet to check hoses at the back and to start disassembling, so to check the hose connected to pump, inlet, anti flood switch and other parts. In this case the best option is locating the manufacturer nearest depot and getting support by your Howden's local representative.
Here the link.
Feb 05, 2012 | Dishwashers
User manual for lamona dishwasher HJA 8630
Hi my salt level indecator light stays on even when I have filled it with salt! please help anyone
Thanks Rose
Dec 24, 2010 | Dishwashers
Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Feb 21, 2010 | Dishwashers
Whirlpool 24 in. GU940SCG Built-in Dishwasher Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
