Question about Samsung Dishwashers
Flashing light SE (Model number DMR77XXX ). Please advise why flashing SE ligh?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Posted on Aug 15, 2009
SOURCE: intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Posted on Sep 04, 2009
  • 949 Answers
SOURCE: flashing lights on dishwasher
If it is the clean light only flashing then take a look at the link below, it will have instructions on how to reset the control and what caused the blinking.
If it is other lights blinking then the user interface (console keypad) needs replaced.
Let me know if this helps
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 13, 2010
Planar PDP-42BK 42" Green Light just Flashes no picture. I am having the same issue. TV worked great yesterday than today I get a flashing green ligh and no picture.
remove all the connection and try to fit somewhere else. the socket which is directly connected to the wall.or then it could be the tube problem inside call some service technician.hope this will help you.
Jun 06, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Flashing green ligh
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 10, 2014 | Tevion AP-DVR18 DVD Recorder
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Sony tv floor model no picture has sound and flashing red light?
How many times do the standby ligh flash at a time? Count that number exactly, and inform me. Flashing number of standby light with Sony televisions are fault indications. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 625 posts to different brand TVs.
Aug 19, 2012 | Televison & Video
My Simpson Eziset 550 won't drain. 2x flashing lights and continual beeping. HELP URGENT PLEASE :-(
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Aug 18, 2010 | Washing Machines
Flashing lights on dishwasher
May 13, 2010 | Kenmore 16072 - Multiple Color Built-in...
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Front Panel Ligh
Either a mechanical problem or the plug has come loose. The possibility that the light actually failed is rather remote...accordianman
Mar 14, 2008 | MGE (CA-DRG-SE) ATX Mid-Tower Case
Dishwashers Logo
20 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
