Question about Emerson NR303TT CD Shelf System
Transformer need to find a transformer for model nr303tt emerson radio. or find out the output of the transformer to find one. the transformer number e190246/hf-48222l2tn does not have that imformation on it.
SOURCE: Emerson NR303TT CD Shelf System
Tienes que llevarlo a un centro de reparaciones ya qur por lo que dices los ICs amplificadores de audio estan danados.
Posted on Apr 12, 2008
  • 979 Answers
SOURCE: Resistor burned on my Grandmother's
Hello Gio, Hi, a burned resistor is usually caused by a shorted part like a semiconductor or regulator, there are two things you should do, find the value of the resistor and what caused the resistor to burned, for the Resistor, the value is usually written on the board, If not you can find the value on schematics diagram (which is usually hard to find, but if you have one, fine), and on the same working model (very remote a possibility). IF this are not available, you now need the assistance of a technician.
Posted on Jan 26, 2011
  • 229 Answers
SOURCE: NEED A DRIVE BELT FOR MY EMERSON NR303TT
www.partstore.com >emerson they will have the drive belt u are looking for
Posted on Feb 25, 2011
bayyagg
  • 1672 Answers
SOURCE: Emerson Heritage Model # NR303TT
Sounds like a dirty volume control switch! If you could open the radio and look for the volume control inside, spray some contact cleaner if there is small hole on the metal cover of that volume control, after spraying play(side to side movement) the knob of the switch so that the contact cleaner would spread inside the switch. If that does not help, you should replace the volume controller switch with the same value.
A simple electronic technician could replace it.
Hope that helps you out!
Thanks for asking FixYa!
Posted on Jul 03, 2011
SOURCE: Nothing on Radio stereo system works.
There is no power whatsoever
Posted on May 27, 2013
Emerson Heritage Model # NR303TT getting very low audio from speakers, even with the volume all the up. Any help is apperciated. Thanks!
Jul 03, 2011 | Emerson NR303TT CD Shelf System
E190246 Transformer Power ? Secondary Voltage ?
The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Apr 25, 2011 | Teac DC-D2831 CD Shelf System
Feb 25, 2011 | Emerson NR303TT CD Shelf System
Resistor burned on my Grandmother's Emerson model NR303TT
Jan 26, 2011 | Emerson NR303TT CD Shelf System
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Nothing on Radio stereo system works. The power comes on nothing plays. There is also CD jamed in the player. Where do I go from here? Emerson NR303TT serial number 61100051 CA
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
Mar 28, 2010 | Emerson NR303TT CD Shelf System
Putting a needle in my nr303tt
the needle should slide on and off. you should consult your owners manual or if you do not have one, you can download and print one from the emerson web site.
Replacment needles can be purchaced from the only authorized distributor of emerson parts(Fox International LTD. , Inc.) (800) 321-6993. Don't forget to provide your model number.
Mar 06, 2009 | Emerson NR303TT CD Shelf System
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
Blown transformer
Greetings!
GPX just received this transformer in stock, at least for model KCLD8886DT. You can contact them at 314-621-2881 and follow the prompts (I think selection 2) or contact them via email at partsinfo@dpi-global.com. The transformer is $15 plus freight. Good luck!
Rob
Jan 08, 2008 | Teac Audio Players & Recorders
Emerson NR303TT Turntable won't work
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. maybe something in the video will clear up exactly how to get the belt on right.
if motor won't spin, spin it with your fingers, sometimes a "dead spot" developes on these motors. if it then starts on it's own, just let it run for a few hrs and the problem may solve itself for a long long time.
Dec 12, 2007 | Emerson NR303TT CD Shelf System
Emerson NR303TT CD Shelf System Logo
88 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
