Question about Measuring Tools & Sensors
ROBINAIR COOLTECH ROB134APF WIL NOT RECOVER VAC
ROBINAIR COOLTECH ROB134APF WIL NOT RECOVER VAC SHOWS 19 inHG BUT WILL NOT RECOVER REFRIGERANT IN LINES. WILL NOT PULL FROM CAR.
mhkamran
  • 180 Answers
SOURCE: I have a Robinair cooltech 700 a/c machine. does
Please check your machine ISV tank liquid hose,it's may lose or too tight
Posted on Jun 11, 2010
mhkamran
  • 180 Answers
SOURCE: i have a a modle 34788 robinair cooltech my day
Please check 1# The compressor suction line with a vacuum gauge & make sure it has 13" HG of suction while you active recover. if not then you need to replace the compressor. 2# Check spin-on filter O rings are fixed properly it may missing or lose, also check filter capacity (amount of refrigerant you have been recover sinc last filter change.every 68KG or 150LBS of recovery you must change spin-on filter)
Posted on Jun 25, 2010
mhkamran
  • 180 Answers
SOURCE: i have a robinair a/c machine cooltech i need to
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Posted on Jul 01, 2010
mhkamran
  • 180 Answers
SOURCE: ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Posted on Jul 10, 2010
mhkamran
  • 180 Answers
SOURCE: robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Posted on Nov 05, 2010
How to fix High pressure message error.
Seems to blockage in the inlet or pressure switch
Jul 01, 2016 | Robinair Cooltech 34788 R134a Automatic...
WILL NOT INJECT OIL
No service manual?
What about support from the folks
you got it from--assuming it is in a shop?
Call Robinair
Jul 15, 2014 | Robinair Cooltech 34788 R134a Automatic...
HELLO I HAVE A ROBINAIR 34788, MY UNIT WILL NOT CLEAR THE LINES. I TRIED SHUTTING OFF AND ON , BUT LINES ARE STILL HOLDING PRESSURE. I ALSO CANT RECOVER BECAUSE IT WILL NOT GET PAST CLEARING. THANK YOU
sounds like you need to check the grommet between the motor and the pump. If this grommet connector breaks, the motor will come on but the pump will not work. Turn the unit upside down and look where the motor connects to the pump. Be aware if you can lose your oil while turning upside down unless you cap the port and exhaust. If this is it, go straight to the Robinair web site and you can order one for around $25.
May 11, 2011 | Robinair CoolTech 6 CFM Two Stage Vacuum...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Robinair cooltech 34788 scale error reset
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi. We've got a CoolTech 34788. Whenever the machine tries to purge air from the tank, we are consistently getting a message saying that the "Air purge timed out". The internal tank shows ~10 lbs of r134a....
It's sound like normal. However when thes message come again you just press Stop/No key to terminates this function. Press Recover & see if the machine is going to recovery after self clearing. If it is then you can continue to work. Hope this will help you best of luck!
Jul 01, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a a modle 34788 robinair cooltech my day shift messed it up is there a way to fix my problim? it wont recover at all. all other functions work (with the lines off i can get it to vacumme)when i hook...
Jun 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
Measuring Tools & Sensors Logo
146 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
