Question about Moen Inc: 1H Srs Kitchen Faucet, CA87003SRS"
No hot water from moen anabelle kitchen faucet model number ca87003
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 49 Answers
SOURCE: My Moen kitchen faucet stopped working suddenly in
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Posted on Sep 03, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
  • 94 Answers
SOURCE: Have a Moen Anabelle faucet and the water is
could be as simple as your aerator is clogged,if not, pull your cartridge and check/replace
Posted on Apr 27, 2010
I need help tightening a kitchen faucet to the sink.
If you look under the sink you shouls see a big nut ...all you have to do is to tighten it while holding the faucet on top at the right place
Mar 24, 2017 | Moen Plumbing
How to tighten a Moen Anabelle CA87003SRS single handle kitchen faucet to sink?
Shut off the water
Clean and dry the area around the faucet.
(from the bottom)
Disconnect/remove the faucet (clean or replace gasket).
Clean the hole completely & apply desired sealant
Positon the faucet in the hole & TIGHTEN (firmly).
Reconnect water lines & restore water supply.
(do NOT over-tighten).
Place clean "printer" paper under each wall valve & supervise
for several days to assure no DROPS are leaving wet marks on the paper.
Be proud.
Carnac the Magnificent
Mar 21, 2017 | Moen Plumbing
Moen single handel kitchen faucet - very little hot water when pushed to hot water side?
Hi Pete,
I'm sorry to hear you are having trouble with Chateau faucet. Please call our consumer services at 1-800-BUY-MOEN and they will be able to help you out with the problem.
Thanks
-Olivia
Dec 28, 2010 | Moen 7430 Chateau Single Handle Kitchen...
Have a Moen Anabelle faucet and the water is restricted, no pressure. Solution?
Mar 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single handle kitchen faucet, Hot water and
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Hot water on cold side when first turned on moen 7600 series
did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Moen Inc: 1H Srs Kitchen Faucet, CA87003SRS" Logo
74 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
